Complete Enclosed Logger
A project log for Isolated Raspberry Pi Data Logger & DAQ Platform
Standalone DAQ with 4 differential analog inputs, 8 digital I/O, temp/humidity sensing, and a 7-inch touchscreen monitor
alireza-noferestiAlireza Noferesti • 07/15/2026 at 13:55•0 Comments
Complete Enclosed Logger (NLDL-VD104-TH01)
A ready-to-use instrument including the logger PCB, Raspberry Pi, 7-inch touchscreen display, UPS HAT, and durable metal enclosure. The built-in UPS HAT supports two 3,500 mAh 18650 lithium batteries for backup power. Batteries are not included to simplify shipping and avoid lithium battery transport restrictions, allowing users to source and install compatible cells locally.
Complete Enclosed Logger Specifications
Measurement & Logging
Analog Inputs
4 differential voltage input channels
Voltage measurement range: ±0.006 V to ±12 V
12-bit differential analog inputs
Sampling rate: up to 30 kS/s per channel
Adjustable logging interval: 50 ms to 1 min
1 MΩ isolated input architecture to reduce channel-to-channel interference
Digital I/O
Digital inputs: 4
Digital outputs: 4
Logic levels: 12 V or 24 V
Output current: 50 mA per channel
Monitoring & Logging Features
Integrated temperature & humidity sensor
Independent data and error logging
Alarm history for event tracking and diagnostics
Connectivity & Interfaces
Temperature & Humidity
For applications requiring higher temperature measurement accuracy, the NLDL-VD104-TH01E model will be available as an option after the campaign ends. This version includes an external temperature probe mounted away from the device housing to minimize the influence of internal heat.
Storage & Data Security
Automatic storage failover: uninterrupted logging during external storage removal, with automatic switching to internal memory if external storage is removed or unavailable
Power System
Integrated UPS HAT
Supports two 3,500 mAh 18650 lithium batteries
Up to 3 hours of continuous operation, depending on battery quality, system configuration, and connected peripherals
Automatic transition between external power and battery operation
Mechanical Specifications
Durable aluminum enclosure
Dimensions: 8.15 × 4.92 × 2.28 in / 207 × 125 × 58 mm
