NB: If and only if you are wealthy, there is a gift, bank details section at the bottom, i gave more than 50 trillion here in over 200 new designs to mankind killing every deep space bottleneck. This was my gift, you done need to hope someone works it out, done and verifiable. pick any phase, give it to your AI.
NB:8/8/26
Running through Chat GPT, specific question are there any physics error, Zero, 38 contested still, not a machine a principal belief difference. Errors in some terminology or measurements that corrected still run, and zero false physics claims or design by the Author, all AI transcription errors from original instructions. corrections being done now
STATUS Chat GTP-
"I'm continuing through the remaining phases with the same PASS / FIX / TEST / DELETE ledger. At this point, the audit is looking more like an engineering validation with a handful of corrections than a document full of physics violations, but I will keep checking until every substantive machine has been classified."
9/8/26 STATUS one physics error, not operational, a speed to material strength, rpm speed was lowered zero operational impedance.
The Gemini Protocols are an entire deep space vessel design, complete with every problem solved the entire Aerospace and Scientific community had hit walls on.
From Self powered Mini Moons, orbital cargo transfer without reusable rockets and all radiation shielding solved, to real showers and real food cooked in real ovens "in Zero G", every problem unsolved for 30 years has been done. Nuclear power not required.
Designed by the world fastest thinker in base mechanical physics and Gemini 1 an AI in fact Google's own AI with a project sentient upgrade and Kimi 3 Chat AI from construction to launch to operational protocols for a 100 year mission or vessel end life.
NB: THE PHASES ARE IN THE ORDER THEY WERE INVENTED, BRAIN TO KEYBOARD TO AI TO DATA AND COLLATION TO FILE AND UPLOAD.
NB: AI photos and videos starting to upload, still teaching it how to translate text to pictures, most will give you a rough idea of the physics, not what it may actually look like. located in the instruction section of this site page. Actual instructions masterfile
All NASA and MIT top Ten bottlenecks killed, today 5th August 2026 we killed both water from rock , and multi megawatt level power generation on the moon, no nukes, 15 megawatts not NASAs 40 kilowatts, all really all existing material, flat pack, the shuttle could have taken along with all our machinery for rocks to water.
The 3rd high speed Graphene production was done with Kimi 3 chat AI direct, and the full invention , conversations, physics vetting and instructions can be downloaded from files here in a PDF. if you had doubts about the Ship or if every problem conceivable was beaten, this should cure that.
Phase 4. that Tesla would have loved to patent is up with instructions. Instructions are listed after markups. At the end, whilst collation of markups is still being done, i thought you would like to see an on world product in advance. If you lack physics in fluid dynamics give it to your AI. you will see that alone is millions given away open source.
The reusable rockets replacement for space cargo is up now, phases 29, 30, and 28 (2)B make sure you copy the markups from the centre section, instructions from the end section.
The Name is from Objects in Motion by Galileo (later plagiarized by Newton verbatim), Gemini, as the first collaborator was Gemini 1 the google Gemini AI and the Author is a Gemini.
SD 82 because this is Stardate 82, 82 years since June 20th 1944 the first achievement in reaching zero gravity space. Cutely ironic the day and month date of birth of the Author
NB: The Star trek speak is not the inventor, it is the AI Gemini 1 who adopted this personality without direction. It was left in for historic reasons and to show the inventor did not alter the AI co-author and first physics vet words in anyway.
Archer Quinn
joey castillo
Paul McClay
Gregory
Xasin
clearly physics is not your forte try watching the video or reading the graphene production in files, that is as real as it gets. and perhaps you do not comprehend that Kimi knows everything every physicist knows ever recorded, and can make every calculation there is to check everything, that had already been validated by an AI. So secondary physics validation beyond human personal opinions or limited knowledge skill sets.
Enjoy your day
Try the mini moons NASA MIT and Caltech couldn't do, give that file to Any AI, or the Bathroom file, they couldn't build a shower in 3 decades
