1Phase 258: Water from Rocks
![Phase 258: Water from Rocks Phase 258: Water from Rocks]()
Water From Rocks - Archimedes mirror preheat - overhead arc flash - no anode required, preheat same tech as the Chinese artificial sun mirror array, the arc is the same as graphene flash production, there is no anode or cathode, base is near full melt fromArchimedes mirror preheat - overhead arc flash - no anode required, preheat same tech as the Chinese artificial sun mirror array, the arc is the same as graphene flash production, there is no anode or cathode, base is near full melt from the array, about 1/20th or less of the Chinese project. That means the platform cools slowly and reheats slowly zero crack in the crucibles. The Arc tech is graphene style flash longer waves less heat, lightning or Arc requires only ground. I designed this before i did the 15MW power station, so now, you could just use induction for the preheat. My Qualification is NPhD, because you are all still operating on P, NP is the only answer. -
2Rotating Toilet bowl - vertical gutter evacuation
Rotating bowl Toilet -not entirely accurate vertical gutter runs to the base, from there it an auger feed no centre, screw walls. text to AI to drawings difficult
3The Upper Primary Bridge
There are 3 full control decks in case of strike 200m apart, those screens are real, in fact Quite old, the US doesn't have them hahaha, sanctions against Huawei and Xiaomi. you can even watch tv on their clear screens- Xiaomi Mi TV LUX Transparent Edition. nothing in the starship is future imaginary, it is build now ready or existing
4Zero G Dual vortex Aquaculture tank - sealed lid, vortex keeps the air in the water
Dual vortex Aquaculture tank - sealed lid, vortex keeps the air in the water, glove access multi point, fish are collected and put in seal lock draws for removal
5Phase 264: Moon Has Full Power Archimedes mirror into high value solar receiver each end of the 1.5MW generators x 10 sets
Moon Has Full Power — the suburb-scale cylinder generator station. 20ft electromagnet and radial multi-pole cylinders in vacuum bays on magnetic float bearings (300mm non-metallic axles, neo/EM tips, front balancer for starts); end points are laser-level solar intakes feeding solid-state batteries — beam from the mirror family is the transmission line; zero-consumable starts: tug clutch-drop on ship, rifle-range berm on Moon. 1.5 MW per mirror-fed cylinder, 15 MW per ten-cylinder bank (one commercial offshore turbine); one bank = one suburb; ~67 banks = NASA's 1 GW full-lunar-economy figure. NASA's rival answer: 40 kW fission at 10 t with a 1 km exclusion zone — one bank out-generates 375 of them. NASA 1596 generation side CLAIMED; night side stays with 210's scalp. 37 Ship 100%, Moon 33%, flat-packs in pods. Amendment 1: the mini 500 kW units — colony spread without cables; generation at the load, the beam is the only transmission line; the colony never grids, same law as the vehicles.
The outer is an illusion, the electromagnets are not stator fashion, the ends are not poles, there are 12 electromagnets perpendicular to the axle facing the outer coil shell, with matching coils. These are wired parallel isolated, if one dies the others are not affected. centre vacuum, moon is a vacuum, low G, objects in motion. tether start spin, sits on maglev style repulsion magnets as bearings to provide frictionless float.![]()
6The Mini-Moon in Space — Sphere Pass (Phase 242)
7The Luna Loop — Motorcycle Hub Hoop (Phase 241-A4)
The forever light stick as a tube for Motorcycle wheels the magnetic ball rolling in the coiled tube lights the LEDs inside that face the outer glow in the dark strontium plastics, so bright when you drive, still glows when you are stopped. All forever lights and mini moons are vacuum sealed.https://dai.ly/xavnl32
8The Luna Loop — Bicycle Wheel Hoop (Phase 241-A4)
https://dai.ly/xavnl3eThe forever light stick as a tube for bicycle wheels the magnetic ball rolling in the coiled tube lights the LEDs inside that face the outer glow in the dark strontium plastics, so bright when you pedal still glows when you are stopped
9Light Family 2 — The Forever Light Stick (Phase 241)
The forever light, now i didn't invent the shaker light, that was decades ago, but they lasted seconds you basically had to keep shaking it, now batteries have short lifespans even rechargeable, so i changed it to a sealed vacuum, ball instead of a cylinder magnet, neo instead of carbon magnet increased power and the vacuum removing friction. then added the glow in the dark plastic to the cylinder outside the coils so it would keep glowing, this was the start of the light family that culminated with the mini moon lights and the laser moon engine on board the ship, already zero G just put in in a vacuum room, manually spun it up, turned on the vacuum, lowered to drive mech that spun it up, zero g vacuum electric engine.https://dai.ly/xavnl3m
10Light Family 6 — The Glow Bracelet (Phase 256) (1)
https://dai.ly/xavnygm mini neo mags in a coil sphere vacuum, shake it or just walk, emergency lighting in smoke or just the dark, or rave bracelets, the catch is actually handcuff snap with button not key
Archer Quinn
