Analog Filter Test Board
Educational PCB for students/hobbyists to play around with analog filters and amplifiers.
Public Chat
This PCB has 5 circuits: Active low-pass filter Active high-pass filter Active bandpass filter Summing amplifier, two inputs Differential amplifier, two inputs Power input: Either +/-5V which goes to two +/-2V5 linear regulators, or connect directly and supply +/-2V5 SMA outputs have 47.5 Ohms series resistance. I have included a 3D printed tray to hold it. The tray uses 4x M3 heat-press inserts, and secures using 4x M3x10mm screws.
Amplifier_Test_Board.step
3D Model of PCBA
step - 16.90 MB - 07/18/2026 at 18:29
Download
3D_Amplifier_Test_Board.pdf
3D PDF of board
Adobe Portable Document Format - 3.26 MB - 07/18/2026 at 18:29
Preview
Analog_Test_Board_Assembly.pdf
Assembly file information
Adobe Portable Document Format - 1.17 MB - 07/18/2026 at 18:29
Preview
Analog_Test_Board_BOM.pdf
Bill of materials
Adobe Portable Document Format - 64.18 kB - 07/18/2026 at 18:29
Preview
Base.STL
3D Printed tray
Standard Tesselated Geometry - 85.82 kB - 07/18/2026 at 18:29
Download
View all 8 files
