Finally got the time to update on the installation over the weekend. After some teething problems related to me and 220VAC I successfully rewired everything from the old system into the network cabinet and connected it to the new Noah unit.
Some will notice that this unit is called the NoahPi Node. This is simply done because the Noah system is already paired with a RaspberryPi for control and will eventually form part of multiple nodes I will be installing at my home and the office as well as as a remote site.
For those interested in how I made the front panel I will add some instructions in the instructions section on creating the front panel.
Below the obligatory installation photos. WARNING: Never mess with your house wiring unless you are qualified to do so or have a friend that happens to be a certified electrician nearby to assist.
Dewet
