How it works
The HC-01 pairs an ESP32 with an SHT40 temperature/relative-humidity sensor and shows the reading on a 1.28" round GC9A01 TFT (240x240). A MOSFET drives a 5 V fan over a gel-bead drawer, and the controller closes the loop: below its humidity band the fan runs, back in band it stops. Firmware is built on ESP-IDF 6 with an LVGL display and a status endpoint over Wi-Fi, and the control logic is unit-tested on the host.
Why a round display
I wanted a gauge — something you can read across the room like the analog hygrometer it replaces. No commercial mount existed for the GC9A01 module, so I modeled a snap-fit bezel and enclosure from scratch and went through several 3D-printed test fits to get the display seated right.
From jumper wires to a custom board
The first prototype was an ESP32 dev board wired to the display and sensor with jumper wires, enough to prove out the display driver, the sensor pipeline (52.2% RH / 25.2 °C on the first live readout), and fan control. It was replaced by a custom PCB with an ESP32-WROOM-32E, USB-C programming via a CH340C, and plug-in headers for the display, sensor and fan. The first batch (rev D) failed with two separate faults. Two boards had an open display header caused by byitl's own tooling: a KiCad flag that stripped the solder-side annular rings. The other three were dead on arrival from a fault in the surface-mount power path that the flag could not have caused. Rev E set that flag correctly, and all five rev E boards work.
What's next
Closed-loop control and field testing are done: the controller runs in a real humidor and switches its fan on and off around the band. Next is making it smaller than 151 x 90 x 45 mm, seating the display carrier properly, and fixing phone provisioning. It can only add moisture, so drying a box that runs high is a separate problem.
More on the build
Full writeup: https://www.byitl.com/blog/hc-01-humidor-controller-jumper-wires-to-custom-pcb
Dead-boards forensics: https://www.byitl.com/blog/custom-pcb-fabrication-when-boards-arrive-dead
Rev E and the fix: https://www.byitl.com/blog/the-annular-ring-fix-held
In a real humidor: https://www.byitl.com/blog/it-works-it-is-also-too-big
BYITL: https://www.byitl.com
Jerome Privott
