Now you see me, now you don't.
A project log for Scottina
A pocket-sized front panel for the diagnostic tools you already use
scottskyScottsky • 08/06/2026 at 17:19•0 Comments
The tile that shows up on its own — and disappears just as fast
Log 1 closed with a promise: hotplug, and how a screen's tile appears the instant its dongle is plugged in and vanishes the instant it isn't. That behavior is what makes the home grid trustworthy — you never wonder if a tool is available, you just look. Here is how it works.
Why not udev rules and hope
The obvious tool for USB presence is udev: write a rule, get an event, react to it. Scottina does not use it for tile visibility. devices.py polls sysfs instead — cheap, no pyudev dependency, no rule files to keep in sync across a Pi image rebuild. The launcher calls refresh() a few times a second, and the tile grid shows a device's tile only while the check comes back positive. Simple beats clever here: one function, one data source, one place to look when a device does not show up.
A catalog of USB ids, and their opinions
Each device screen is gated on a set of (vendor, product) USB ids — SDR_IDS for the RTL2832U dongles, ALFA_IDS for the Wi-Fi sniff adapter, CANABLE_IDS for candleLight/gs_usb boards, FTDI_IDS for the serial adapters. Most of these are a clean lookup. A few are not:
None of this is guesswork. Every id in the table is a fact recorded on the bench with the actual device in hand, not a datasheet guess — the comments in devices.py say so, including the date for the CanTick case.
The tile follows the truth on the panel
Fixed screens — LAN Scan, Wi-Fi, Pi Health — are always on the grid. Device tiles are not: they appear only while refresh() finds their id present, and they carry a small green "live" badge so it is obvious at a glance which tools are physically available right now versus which ones would need a dongle first. Unplug the RTL-SDR mid-session and its tile is gone on the next poll, no stale entry pointing at hardware that is not there anymore.
Adding a device is a known recipe, not a one-off
This pattern gets reused every time a new piece of hardware joins Scottina. The logic-analyzer integration is the clearest recent example: Phase 2 of that work is nothing but "add the FX2LP ids to devices.py using the same mechanism the other screens use, gate the new screen's tile on that presence, done." No new detection framework, no special case in the launcher — just another entry in the same table. That reuse is the actual payoff of building the mechanism once and keeping it boring.
Next log: what happens after a tile is tapped and the tool is a web app — how Scottina waits for Node-RED or Kismet to actually answer on their port before it tells you where to point a browser, instead of guessing that a spawned process is a serving one.
