• Log 3
    Rafael Vogler • 10/30/2026 at 02:53 • 0 comments
    Progress is slower than I would like. The IB Diploma Program is swallowing most of my time.
    That being said, progress exists. In this log, I will outline my plans for a secondary electron detector, my Wehnelt cylinder, my (potential) magnetic lens and its manufacturing, my scanning electromagnet design, plans for precision alignment, the circuit I have built and made physically work (in a weekend) to connect to a Moducell 325 and Pfeiffer IKR 251 including interlocks, my attempts to revive a GP275 Convectron Gauge, and the upgrades I am making to my Shapeoko 5 Pro to facilitate precision machining.
    Topic 1.1: Electron Optics
    Figure 1: A diagram of my current magnetic pole piece design, before electron simulation optimization.
    The pole piece is going to be an asymmetric snorkel lens pole piece that I have the capacity to machine with my Shapeoko 5 pro, electropolishing, and compound diamond paste, with precision rods for alignment. Any flip-sided machining introduces relatively large error that I wanted to avoid, so I designed 2 pieces capable of being machined purely single-sidedly and then combined together with an upper and lower pole piece when both are machined (Figure 1). All that being said, whether or not I make this design depends on whether or not my simulations say it is better than a bare N52 neodymium magnet. Also in the works: An electron Boris-pusher I’ve made that currently runs 5 billion particle-steps in a few tens of seconds and a FEnICSx electrostatics simulator that I can programmatically give my geometry, all tied together into a single electron column optimizer. This part is delayed until after January.
    Topic 1.2
    I analyzed multiple secondary electron detector designs for this project. The first one, present in the article I base my work on, is BSE (Backscattered Electron) detection. When the high-energy electron beam hits the sample surface, most electrons become backscattered electrons. You can read more about it here. The problem with this detection method is that it is fundamentally limited by the interaction depth of the electrons. High-energy electrons can penetrate hundreds of nanometers to micrometers through a sample surface and scatter through a volume rather than off a surface - thus, topographic information cannot always be extracted from BSE imaging. While I will build it in as it is quite cheap, I also want to get secondary electron detection. The standard secondary electron detection method is Everhart-Thornley detection. I was repulsed by this idea as it requires me to work with more high voltages and scintillators unless I buy an incredibly expensive pre-made detector. Gaseous Secondary Electron Detection is a more budget option, and it seems great - it needs a transimpedance amplifier and a low-high voltage of 400V - but my pole piece design magnetically projects into my sample chamber, so I cannot guide the weak secondary electrons anywhere. I needed something other than electrons — photons, which aren’t affected by magnetic fields! Gases such as nitrogen and water vapor emit UV light when ionized by accelerating secondary electrons in the Townsend cascade, which can then be collected by a light pipe (or a few) and sent to a Photomultiplier Tube (PMT). PMTs are sensitive enough to detect singular photons so it will push my noise limit to shot noise of electrons, meaning I can cull the current of my beam to picoamperes.
    Topic 1.3
    Rafael! Rafael! If you’re shooting a laser into your chamber… and you’re also making your detection system based on photons… aren’t you going to drown your signal in a laser?
    Yes. I didn’t initially think about this, but 1 milliwatt of 405 nanometer light or more (15 quadrillion photons per second) is going to enter my chamber every second to thermally excite the electrons in the carbon nanotubes enough for them to jump out and fly far away.
    Figure 2: Diagram of the photon problem.                 ...
  • Vacuum Gauges and Microcontrollers
    Rafael Vogler • 08/21/2026 at 03:40 • 0 comments
    Three things, other than buying the rest of the vacuum parts, have to happen before the vacuum system can be fully assembled and tested:
    1. I must make a sort of cleanroom space for assembly using a HEPA filter and zipwalls. So far, I have reorganized all of my items and created a clean floor space, but I have yet to add the zip walls.
    The wooden cabinet is going to be what holds my SEM. It is remarkably sturdy. the roughing pump will be located either on the floor or on another table to isolate its mechanical vibrations from the SEM column.
    2. I must make a cryogenic baffle using copper disks, copper threaded rods, m3 nuts, indium foil, dry ice, and acetone. Since I am an amateur, building any kind of vacuum feedthrough is a thing that I would prefer to avoid as long as I can, hence my use of indium foil to get thermal contact instead.
    The 3 rods will be threaded in reality and will be crushed into the sockets on the 2 discs with nuts
    3. I must make a vacuum gauge reader circuit for the Moducell 325 and Pfeiffer IKR 251 that does not introduce catastrophic arcing paths to my Raspberry Pi master computer. This has been my main time-consumption considering I had no knowledge of electronics prior to this, but I've been learning somewhat. My schematics remain abhorrent, however. At the top right is a galvanically isolated 24VDC power supply that I will be connecting to a mean well 24VDC power supply or similar . At the top left is an array of optocouplers I will be using for data transmission (they will likely only be able to manage 9600 BPS, but I don't need fast data transfer). They are taking advantage of USART, with one TX and one RX line on the left side and the 2 optocouplers on the right connecting to BOOT0 and NRST, allowing me to reprogram the STM without opening up the box each time. At the bottom is where I connect to both my Moducell 325 (9-pin) and Pfeiffer IKR 251 (6-pin). The Moducell 325's output goes into the MCP6002 op-amp's unit A, with a fractional gain setup that also eliminates common mode noise. The output of the op-amp goes into one of the STM32's pins connected to its 12 bit ADC, which I figured would give me enough steps for vacuum pressure considering the linear nature of the output of the Moducell and IKR. The Pfeiffer IKR 251, meanwhile, has both lines routed into the STM32's pins through a voltage divider of 2/7 for each, turning the 10.5V maximum output of the IKR 251 to a 3V output. Between the 9 pin and 6 pin connectors is a hardware interlock, utilizing the set point of the Moducell. Pin 6 is the set point common that carries over into pins 1 and 2. Pin 1 connects to pin 6 when the Moducell detects that the pressure is below the set point, while pin 2 connects to pin 6 when the Moducell detects the pressure is above the set point. When Pin 1 carries 3.3V, it goes into the gate of an N-channel MOSFET and connects the gate of a P-Channel MOSFET to ground through a 20k resistor, dropping 8V from the total 24V when active and staying within the +-12V gate to source voltage limit of this particular MOSFET. There is also one more N-channel mosfet in series with the hardware interlock which is a manual 'go' button routed from the STM32, meaning the IKR 251 will not turn on unless both my system and I tell it that it can. The PCB layout, so far. Don't laugh, I'm new.
    Meanwhile, I have also been working on a project to convert a GP275203 passive convectron gauge into an active one, since I got one with a foreline trap I bought a few days ago.
  • Backlog - High Vacuum Stage
    Rafael Vogler • 08/02/2026 at 07:54 • 0 comments
    I have been researching this project for months, and as such, I have a backlog of information to give.
    Everything within my project is based on an article titled "Concept and Demonstration of a low-cost compact scanning electron microscope" by Kuzyk, C., Dimitrakopoulos, A. & Nojeh, A. Initially, I sought to understand the core principles of a scanning electron microscope. In June of this year, 2026, I began amassing parts to tackle the first challenge - high-vacuum. I aim to complete this part by the end of August, but will likely actually finish by the end of September.
    In order to acheive high vacuum, 2 things are required to work in tandem - a roughing pump, and a high-vacuum pump. I elected to use a diffusion pump for my project, which I bought for $400 from ebay - the mcf60-01, a decades-old pump made by CVC (Consolidated Vacuum Corporation). As for my roughing pump, I bought the StonyLab dual-stage rotary vane vacuum pump given the high cost of more lab-suitable options, for $100. These 2 form the backbone of my vacuum system.
    The Vacuum Valve Layout:
    This is my vacuum design, simplified in 2D. The "LV" label is my Low-Vacuum pump from stonylab. It can acheive an ultimate pressure of 0.3 Pa nominally, which clears out the entire outlined SEM through the 2 paths for rough vacuum. The purpose of the 2nd, lower path is to clear out the area below the objective aperture since it is 0.1mm and necessarily divides the microscope into 2 pressure zones, should I ever need it in future iterations.
    There are 5 valves in my design.
    Valve 1 permits the roughing pump access to the foreline input of my diffusion pump, and is a ball valve given the vacuum levels.
    Valve 2 permits the diffusion pump access to the high-vacuum chamber, and is a right angle bellows isolation valve.
    Valve 3 permits the roughing pump access into the high vacuum area, and is a butterfly valve.
    Valve 4 permits the roughing pump access to the entirety of the chamber, including the low-vacuum part, and is a ball valve.
    Valve 5 permits repressurization, and is a metering needle valve.
    For an example of the sequence of valve openings, I'll pretend I'm trying to change the sample. in order to do so, I close valve 4 (which connects to the roughing tube) and valve 2 (the high-vacuum isolation valve). Then, valve 5, a metering valve, is opened to let air in slowly and repressurize the chamber while the gauges and electron emission source is turned off. This allows me to perform a sample change. However, after the sample change is done, I need to remove the air from the chamber once more, while my diffusion pump is still hot and running. In order to do this, I exploit the overpowered strength of my roughing pump at 3.2 CFM facing a chamber volume of millileters, and close that foreline valve (number 1), while opening valve number 4 and valve number 3 (the roughing valve). Within seconds, I get pump-down, and can close valve number 3, open valve number 1, and close open valve number 2 in seconds, well before the diffusion pump breaks down from high pressure at the foreline.
    G1 and G2 on my diagram are gauges, and will have separate electrical circuits driving them.
    In order to get the high vacuum made with a slightly lower headache, I rely on standardized KF parts. However, that's clearly a problem with the decades-old MCF60-01 I purchased. So, I had to machine aluminum adapters, which I will connect with EA 1C epoxy to standard KF weld stubs.
    The aluminum adapters in question, near the end of their machining cycle on a Shapeoko 5 Pro. July 17th.
    The catastrophic collateral damage involved in creating said aluminum adapters while being a newbie at machining, framed in an oddly cinematic shot (look in the background for the end mill graveyard). The first end mill was snapped from an incorrect plunge in software, and the other 3 were snapped as I brutally sent them to shatter themselves on the remains of the first. This final 5th end mill...
