Assembling LIDAR mechanics
A project log for Open Simple LIDAR
Open Source scanning laser rangefinder
iliasamiliasam 08/06/2017 at 18:100 Comments
First step is building "main plate" - it is the part that holds ball bearing, motor, and some other parts. This part can be cut from some flat plastic plate. I have used 5mm acrylic glass:
Drilling 42 mm hole for bearing was a little tricky.
This part can be printed at 3D printer.
Next step is assembling everything.
Photos of assembled mechanics (top view):
Side view:
Motor is connected with the PCB holder with rubber belt.
Down view:
Here it can be seen method of fixing the PCB holder to the ball  bearing.
Next step is to fix encoder at the "main plate" and to test it.
