DOGS² Enclosure: Sharp Edges or Rounded Corners?
A project log for DOGS² — Dual Output Generator Supply Station
Standalone open-source board bring-up station: dual programmable power: up to 48V/3A, current monitoring, diagnostics, In 5–90V DC or USB-C.
sergeiSergei • 08/05/2026 at 13:16•0 Comments
The DOGS² enclosure design has been completed as a 3D model. The images show the enclosure with the boards installed inside, along with two versions of its exterior design.
The overall dimensions and internal layout are the same in both versions. The only difference is the treatment of the outer edges: the first version retains sharp corners, while the second adds fillets.
I have not yet decided which version suits DOGS² better. I would like to hear the community’s opinion: which enclosure would you choose—one with sharp edges or one with rounded corners?
