One LOW in 128 HIGH Lines — A Public Domain ASCII Memory Architecture
Wolf13 / Alan Cyr / CYR Technologies / Chicago / August 2026
This is a public domain release. Two circuit architectures — the DTL Hold
Circuit and One-Hot ASCII Storage — are free for anyone to use, build,
sell, or improve. No license. No royalty. No attribution required.
THE MECHANISM — DTL INVERTER, DIODE ARRAY SWITCHING
The DTL Hold Circuit is built from two DTL inverters. The switching is
not done by the transistors — it is done by the diode array operating
on unbalanced contact potential. The transistors are output stages.
The diodes make the decision.
Each position in the array has B+ through a pull-up resistor to a node.
From that node: one diode to its own transistor base, and diode
connections to all other positions' collectors.
When one transistor conducts (collector LOW):
  Active collector LOW + one diode drop  = ~0.8V at all inactive nodes
  Two diode drops required to drive base = ~1.2V minimum threshold
  0.8V < 1.2V — inactive transistors cannot conduct
The switching decision is made entirely by the diode contact potential.
No clock. No stored charge. No capacitor. No cross-coupled transistors
fighting each other.
The 127 HIGH collectors simultaneously sustain the active base through
their diodes — well above the conduction threshold. One transistor always
conducts. One current path: B+ → R → collector → GND.
This is not near-zero power in the hold state. It is exactly one current
path, set by the designer through resistor selection.
The principle can be demonstrated with a bicolor LED indicator — no
transistors at all, just diodes — switching state based purely on
contact potential. The DTL Hold Circuit extends that primitive to N
positions through the diode matrix.
THE PROBLEM WITH EVERY EXISTING APPROACH
Every memory technology in common use fails at least one of seven
conditions:
  Clock-Free | No Capacitor | No Forbidden State | No Metastability
  No Refresh | One-Step Write | Radiation Hard
SR Latch: two transistors opposing each other. Forbidden state S=R=1.
  Race conditions at boundaries. DTL: diode array decides — no opposing
  transistors, no forbidden state possible.
SRAM (6T): six transistors, two opposing sides. One cosmic ray flips
  both cross-coupled nodes. Passive topology, no active defense.
DRAM: stored charge leaks. Must refresh every 64ms forever. At high
  temperature, retention drops from 64ms to milliseconds — catastrophic.
Spin-Flip MRAM: no clock, no capacitor, but still two-step writes,
  thermal stability wall at Curie temperature, and scaling limits.
The DTL Hold Circuit passes all seven conditions. It is the only
technology in the comparison table with a checkmark in every column.
ONE-HOT ASCII STORAGE
128 transistors in a row. All OFF by default — no base drive available.
The stored character is the single transistor that conducts. Position is
meaning. No encoding. No decoding. No clock to read.
  Line 65 conducting = letter A stored
  Line 66 conducting = letter B stored
  Line 32 conducting = SPACE
  No transistor conducting = NULL / idle
To write B when A is stored: pulse position 66. The diode array
immediately transfers the active state. Line 65 releases. Line 66 holds.
One move. Erase and write are the same event.
Binary ASCII stores a character across 7-8 flip-flops — 42 to 48
transistors minimum in SRAM. One-Hot ASCII stores the same character
with one transistor...
