One LOW in 128 HIGH Lines — A Public Domain ASCII Memory Architecture
Wolf13 / Alan Cyr / CYR Technologies / Chicago / August 2026
This is a public domain release. Two circuit architectures — the DTL Hold
Circuit and One-Hot ASCII Storage — are free for anyone to use, build,
sell, or improve. No license. No royalty. No attribution required.
THE MECHANISM — DTL INVERTER, DIODE ARRAY SWITCHING
The DTL Hold Circuit is built from two DTL inverters. The switching is
not done by the transistors — it is done by the diode array operating
on unbalanced contact potential. The transistors are output stages.
The diodes make the decision.
Each position in the array has B+ through a pull-up resistor to a node.
From that node: one diode to its own transistor base, and diode
connections to all other positions' collectors.
When one transistor conducts (collector LOW):
Active collector LOW + one diode drop = ~0.8V at all inactive nodes
Two diode drops required to drive base = ~1.2V minimum threshold
0.8V < 1.2V — inactive transistors cannot conduct
The switching decision is made entirely by the diode contact potential.
No clock. No stored charge. No capacitor. No cross-coupled transistors
fighting each other.
The 127 HIGH collectors simultaneously sustain the active base through
their diodes — well above the conduction threshold. One transistor always
conducts. One current path: B+ → R → collector → GND.
This is not near-zero power in the hold state. It is exactly one current
path, set by the designer through resistor selection.
The principle can be demonstrated with a bicolor LED indicator — no
transistors at all, just diodes — switching state based purely on
contact potential. The DTL Hold Circuit extends that primitive to N
positions through the diode matrix.
THE PROBLEM WITH EVERY EXISTING APPROACH
Every memory technology in common use fails at least one of seven
conditions:
Clock-Free | No Capacitor | No Forbidden State | No Metastability
No Refresh | One-Step Write | Radiation Hard
SR Latch: two transistors opposing each other. Forbidden state S=R=1.
Race conditions at boundaries. DTL: diode array decides — no opposing
transistors, no forbidden state possible.
SRAM (6T): six transistors, two opposing sides. One cosmic ray flips
both cross-coupled nodes. Passive topology, no active defense.
DRAM: stored charge leaks. Must refresh every 64ms forever. At high
temperature, retention drops from 64ms to milliseconds — catastrophic.
Spin-Flip MRAM: no clock, no capacitor, but still two-step writes,
thermal stability wall at Curie temperature, and scaling limits.
The DTL Hold Circuit passes all seven conditions. It is the only
technology in the comparison table with a checkmark in every column.
ONE-HOT ASCII STORAGE
128 transistors in a row. All OFF by default — no base drive available.
The stored character is the single transistor that conducts. Position is
meaning. No encoding. No decoding. No clock to read.
Line 65 conducting = letter A stored
Line 66 conducting = letter B stored
Line 32 conducting = SPACE
No transistor conducting = NULL / idle
To write B when A is stored: pulse position 66. The diode array
immediately transfers the active state. Line 65 releases. Line 66 holds.
One move. Erase and write are the same event.
Binary ASCII stores a character across 7-8 flip-flops — 42 to 48
transistors minimum in SRAM. One-Hot ASCII stores the same character
with one transistor conducting through one resistor. No encode. No
decode. Read by detecting which collector is LOW.
ERROR IMMUNITY — ACTIVE SUPPRESSION, NOT PASSIVE TOLERANCE
To cause an error, something external must inject enough current into an
inactive base to cross the 1.2V diode threshold AND sustain that current
against the active collector's sink — which is always present, always
fighting back.
A single-event radiation upset deposits charge transiently. It cannot
sustain current against an active low-impedance collector. The circuit
is not passively tolerant — it actively suppresses the upset in real time.
The immunity gap (0.8V vs 1.2V) is controlled by the designer through
supply voltage and resistor selection. Higher supply voltage = larger
gap = greater immunity. This is not a fixed physical property — it is
a designer-controlled margin.
SIMULATION
18-position one-hot verified in LTSpice (CYR_OneHot_18way_v3.cir).
Sequential LOW pulses, V(c1) through V(c18), one active position at a
time, all others held OFF by the diode contact potential network.
Architecture scales identically to 128.
THE NUMBERS
In a conventional CPU:
Clock distribution: ~35% of chip power
Encode/decode logic: ~15% of chip power
Refresh cycles: ~8% of chip power
Total addressable: ~57%
Global data centers consume approximately 250 TWh per year. At full
adoption of this architecture within the character-storage and
asynchronous control domain: ~144 TWh annually addressable, equivalent
to ~58 million metric tonnes of CO2 avoided per year — roughly the same
as permanently removing 13 million cars from roads worldwide.
PROJECT FILES
cyr_onehot_storage.v — Parameterized Verilog RTL, N=128, public domain
CYR_OneHot_18way_v3.cir — LTSpice 18-position netlist
6wayswitch.dsn — 6-position schematic
PUBLIC DOMAIN DECLARATION
Alan Cyr (Wolf13), Founder and CTO of CYR Technologies, Chicago,
releases the following to the public domain as of August 2026:
(A) The DTL Hold Circuit
(B) One-Hot ASCII Storage
(C) The No-Clock, Not-Binary Computing Architecture
Free to use. Free to build. Free to sell. Free to improve
No license. No royalty. No restriction. No attribution required.
Prior art date: August 2026 — Wolf13 / Alan Cyr / CYR Technologies.
Alan Cyr
