A Possible alternative to using the relay board
A project log for IoT Bubbles
Who doesn't like bubbles, now you can control your own bubble machine from anywhere!
mcunerdmcu_nerd 05/26/2017 at 20:150 Comments
The off-the-shelf relay board does fine for turning the bubble machine on/off but I've been thinking about controlling it via a MOSFET. I created a schematic and board file (still have to clean up the labeling) for a MOSFET board which I'll likely use for other projects as well. If it goes well, I'll likely be posting a separate project page for that.
