i2c-over-rj45
Differential I2C over Cat5e using the PCA9615. Two identical boards, one at each end, 100 m tested.
Public Chat
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
### The 400 pF wall I2C was never meant to leave the board. SDA and SCL are open-drain, held high by a pull-up resistor, so every edge is an RC charge curve — the resistor against whatever capacitance is hanging off the bus. The spec caps that capacitance at 400 pF, and a metre of ribbon cable eats most of it. Past that the rise time misses the timing budget and the bus stops working, or worse, works until the room gets noisy. The other two failure modes are quieter. Single-ended signals referenced to a local ground have no common-mode rejection, so a long run acts as an antenna. And two boards several metres apart rarely share a ground potential; the offset shifts the logic thresholds until a high stops reading as a high. You can paper over the first problem with stronger pull-ups. You cannot fix the other two without changing what is on the wire.
