Magnetic Connector HotSwap Protection Board
A PCB to protect from shorts when using exposed magnetic connectors
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
I built a modular tool system for DeWalt batteries that uses a magnetic connector. The problem is that it would be dangerous to supply direct battery voltage with an exposed connector. Normally magnetic connectors solve this issue by using a sense wire (or 2) but if all you have is positive and ground, then that isn't viable. I found the Monolithic Power Systems MP5056 hot swap IC which is perfect, but but I couldn't find any modules so I designed this PCB. The KiCad project is on my GItHub if anyone is interested in creating one of these.
