A custom industrial 2-layer PCB designed around the STM32G0F6Px microcontroller, featuring an integrated 24V-to-3.3V step-down buck converter, low-side MOSFET drivers, and hardware-conditioned sensor inputs for automated RO system management.
System Functions & Peripherals
Input Voltage:
24V DC main power supply (stepped down to 3.3V for logic).
Actuator Control (Low-Side MOSFET Drivers):
Inlet Solenoid: Controls feedwater inflow to the RO membrane.
Flush Solenoid: Handles periodic high-pressure membrane flushing.
Booster Pump: Drives high-pressure water delivery through the filter stages.
Sensor Inputs (Filtered & Conditioned):
High-Pressure Switch: Detects full tank pressure to shut down pumping.
Low-Pressure Switch: Detects water feed loss to prevent pump dry-running.
TDS Sensor: Measures Total Dissolved Solids / water purity output.
