This project showcases real-time Linux images for BeaglePlay and BeagleBone Black SBCs, designed for out-of-the-box use as PTP Grandmaster and Slave devices. It features a custom kernel and a timerfd-based verification script with the following properties:
Integrated with the PREEMPT_RT patch for real-time performance.
Device Trees Configured for interfacing with pps-gpio drivers.
Automatically initializes PTP on startup for both Slave and Grandmaster devices.
Uses an initramfs-based kernel with an EROFS root filesystem for immutability.
Includes instructions to mount each filesystem image—FAT32 (boot), Ext4 (kernel & device tree), and EROFS (rootfs)—along with the kernel configuration files.
Features a statically compiled pps-pulser.c program for oscilloscope verification of post-sync user-space latency.
Follow the github link provided in the project links section , github page has extensive implementation guide for customising the final images , along with the guide to simply download and install those images for direct use
