PickOMatic V2 : RISC-V Pick and Place Controller
An open-source, all-in-one motion control board for desktop pick-and-place machines. RISC-V, Ethernet, USB-C, 7 stepper drivers on board.
Public Chat
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
PickOMatic V2 is a professional-grade motion controller designed from the ground up for desktop pick-and-place machines. It is the second generation of my PickOMatic project, completely rebuilt around a modern 32-bit RISC-V microcontroller. WHAT'S ON THE BOARD - WCH CH32V317VCT6, a 32-bit RISC-V MCU in LQFP-100, replacing the 8-bit ATmega2560 of V1 - 7 stepper channels with on-board DRV8825 drivers: dual-X and dual-Y gantry, Z axis, plus auxiliary picker-head axes - Per-channel microstepping selection with M0/M1/M2 solder jumpers and current trim potentiometers - Native Ethernet with on-chip PHY and RJ45 magjack for reliable G-code streaming over the network - USB-C for setup, control and firmware workflows - Relay outputs (NC-COM-NO) for the vacuum pump and pneumatic accessories - 3 servo outputs for independe
