NES Radar turns a real Nintendo Entertainment System into a live air traffic scope.
Type any airport's four-letter ICAO code on the NES controller, press Start, and the aircraft actually flying near that airport right now appear as moving targets on your TV.
It works for airports worldwide. Point it at your local field and watch the approach traffic line up, or at KLAX and watch it get busy. Watch this quick video demo. Visit the GitHub repository for the latest software (python script and NES rom file)
The NES can't reach the Internet, so a small server on your computer fetches live traffic from adsb.fi and streams it down the controller cable. The NES sends your airport choice back up the same cable.
This project is based on c64u-radar, a similar program for the Commodore 64.
What you need
This is a hardware project, not a download-and-play ROM.
An FT232R-compatible adapter is what this project is tested against. The server lists every serial device it finds and lets you pick, but other adapters may behave differently, electrically or in timing.
Downloads live on the GitHub Releases page: the ROM, the macOS Universal binary, the Python source archive.
Caution
Connect your vintage NES to your modern computer at your own risk. The authors are not responsible for damage caused by this experimental project.
Get a 5 V TTL cable
Use a 5 V USB-to-TTL serial cable. The recommended reproducible part is the genuine FTDI TTL-232R-5V-WE. Testing has been done with FT232R-compatible adapters at 5 V. Others may work but use at your own risk.
Do not use a 3.3 V adapter. Its 3.3 V TX output is not a reliably guaranteed logic high for every 5 V NES input buffer. A genuine FTDI TTL-232R-3V3 has 5 V-tolerant inputs but it may not drive the NES reliably. The USB ID 0403:6001 identifies the FT232R family; it does not tell you whether a cable is 3.3 V or 5 V.
You can use an old controller cable or purchase a new replacement controller cable or controller extension which can be cut to size.
Connections
With the NES powered off and USB unplugged, connect to controller port 2:
| FTDI pin | NES controller port 2 | Connection |
| GND | pin 1 — GND | direct |
| RXD | pin 3 — OUT0/LATCH | **through its own 1 kΩ series resistor** |
| TXD | pin 4 — D0 | **through a separate 1 kΩ series resistor** |
| VCC +5V | — | **not connected; insulate** |
| CTS# | — | not connected; insulate |
| RTS# | — | not connected; insulate |
Important
There are two separate 1 kΩ resistors, one in each signal direction. Do not join RXD and TXD together, and do not connect OUT0 to CTS. Insulate the unused VCC, CTS, and RTS leads individually.
Plug a normal controller into port 1 — that's what you use to enter the airport code.
Full port pinout, viewed looking into the jack on the front of the console:
pin 1 GND  -- |o\
pin 2 CLK  -- |o o\ -- pin 5 +5V
pin 3 OUT0 -- |o o| -- pin 6 D3
pin 4 D0   -- |o o| -- pin 7 D4               '--'
Check your orientation before soldering. The plug's mating face and its wire/solder side are mirrored. Confirm you are counting pins in the direction above — not from the back of the connector. See the NESdev controller port pinout.
Double-check pin continuity. Do not rely on wire color alone. NES controller cables all use different colors. Identify NES-side wires by continuity and pin number, never by color alone. See the NESdev serial cable page.
A correctly built cable measures about 1 kΩ on each signal and about 2 kΩ through the two-resistor loop.
Why each line
Both signals run 9,600 baud UART. TXD → D0 carries the radar scenes from the server to the NES. OUT0 → RXD carries your ICAO code and the Select-button pause request back the other way. Each 1 kΩ series resistor limits fault current during a miswire, contention, or the common case where USB is powered while the NES is off. Neither meaningfully affects the signal at 9600 baud.
The NES controller-port input buffer inverts D0, which the ROM corrects in software. The reverse direction needs no inverter: OUT0 high is UART mark, OUT0 low is space.
Leaving either wire disconnected gets you a scope that never accepts an airport.
Before you power anything on
This wiring was accepted on an NTSC NES. Some PAL consoles have additional protection diodes on the controller port; PAL compatibility is not claimed.
Running the server
macOS
The macOS build is a self-contained Universal 2 binary — it carries its own Python, pyserial, and HTTPS certificate bundle, so there's nothing to install.
Unzip it and start the launcher:
cd NES-Radar-0.4.4-macos-universal
./start_nes_radar_server.command
You can also just double-click start_nes_radar_server.command in Finder.
The build is ad-hoc signed but not notarized, so the first launch is blocked with a warning about an unidentified developer. Open System Settings → Privacy & Security, find the message about nes-radar-server, and click Open Anyway. You only do this once — after that the launcher starts normally.
Sanity check before wiring anything up:
./start_nes_radar_server.command --self-test
Start through the launcher rather than running nes-radar-server directly. It passes your arguments straight through, and it keeps you on the copy macOS has already approved.
If you would rather clear the warning up front, this removes the quarantine flag macOS puts on files downloaded from the web:
xattr -dr com.apple.quarantine .
Do that only after checking your download against SHA256SUMS.
Windows and Linux
There is no prebuilt binary for Windows or Linux — both run from the Python source package, which needs:
Install them in a virtual environment so the source package works with distribution-managed Python installations, including Homebrew Python:
# Windows
python -m venv .venv
.venv\Scripts\activate.bat
python -m pip install -r requirements.txt
start_nes_radar_server.bat
# Linux
python3 -m venv .venv
. .venv/bin/activate
python start_nes_radar_server.py
The macOS binary carries Python, pyserial, and the CA bundle; binary users install none of these separately.
Real-hardware acceptance has been done on macOS. Treat Windows and Linux as the experimental path.
Using it
  1. Load the ROM on the NES.
  2. Start the server and pick your serial device from the numbered list.
  3. Enter an airport ICAO code on the NES and press Start.
Changing airports. Press Select on the scope, wait for the ICAO editor, type the next code, press Start. Leave the server running the whole time — a pause handshake keeps the old traffic from scrambling the editor.
Reading the link. The LINK field shows what the connection is doing.
If you restart the server while the ROM is already on the scope or at LINK WAITING, reload the ROM before starting a new session.
If the server is transmitting but the ROM stays at LINK WAITING, check the D0 connection and the common ground. The host can confirm bytes written to the adapter, but it cannot prove the NES received them.
If the ROM never leaves the airport editor, check the OUT0 → RXD side — the reverse path. The host can't tell the difference between a NES that isn't sending and a NES that's sending into a disconnected pin.
