After checking the board, mostly visually, all appeared to be OK. The first power-on was to be tested with the logic only, so the only elcos in the serial line drivers don't matter at this time.
Raising the current carefully and observing the behavior of the device, all appeared to be electrically OK. At 5V the current needed was 180 mA, something expected of that many CMOS packages on the board.
Some status leds turned on but nothing on the display.
That, however, is expected, as the 8 dots in the display only appear after the debugger has detected the processor. For that a live processor is needed in the target processor socket. Also some target system should be there, but lacking that the self-test card that came with the system can be used. Except that no self-test card came with it.
However, the manual has the circuit for the self test card, so the next step is to make one.
However (again), some checks can be made right away, the interesting one is to see if the system's own processor is alive. Quick check with oscilloscope showed that the crystal oscillator is running. The next check was to see the timing pulses TPA and TPB.
Those appear to be OK, too.
So the next step is to make the self test card and check the system further.
Lauri Pirttiaho
