Good news, it works
A project log for CDP18S030: A Microcomputer in a Briefcase
Breathing life into a half a century old RCA COSMAC Micromonitor emulator of CDP1802 microprocessor
lauri-pirttiahoLauri Pirttiaho • 09/21/2026 at 19:55•0 Comments
Tinkering the self-test card took some prestidigitation with sharp knife, LT1SC soldering tip, and Leica A60.
The oscillator was made as described in the previous log. The inverter for the EF1 was made of a '1G57 multi-function gate.
After plugging in the card and the processor nothing remarkable appeared to happen. No eight dots on the display, suggesting the Micromonitor could be faulty. But not really. The manual tells to use known good processor as the target, and untested recycled processor is not such a thing. So after inspecting the device with oscilloscope, it seemed almost to work, sometimes.
After some closer study, it became obvious that the pins of the target processor were so dirty and oxidized that even the first time to get to the 8-dots prompt was a miracle. So cleaning the pins by removing the old solder and cladding with fresh tin, the processor began to respond correctly to the Micromonitor. No issues with the self test circuit so far.
After a little playing with the debugger it seems to be alive.
The keypad has some contact issues as well as some bouncing, but nothing really unexpected so far.
So, now that I have and in-circuit debugger, I need a circuit to debug in. And what would be more apt to the theme than make something like Cosmac ELF? The schematic can be found in the net. However, some components may be hard to come by, so have to improvise.
For the RAM I found a 2 kB TC5517AP. Simply tying the high address lines low I can start with 256 bytes aliased across the whole memory space, like the original one. A bit more difficult to find are the two hex displays with internal latch and binary to hex chars converter. That calls for a hack...
