Provides 5v power via USB-C. New version(not the one pictured) Has efuse for ovp, ocp, ptc for ovp but its slow to react.
Creates Composite video using a a733 transistor and also provides a jumper for RGB if you happen to be using a nesrgb or something similar. Cannot Connect both composite and RGB at the same time.
Vijayasarathy Shastri
controlmypad
Stefan Wagner
Andrew
fixed. correct file has been uploaded.
