Vacuum Tube Computer
This is an 8 bit vacuum tube computer I built using recycled 1950s Vacuum Tubes I found in Eastern Europe a few years ago.
Vacuum tubes are Defo Retro (as my grand children would say). The finest 6N3P tubes were selected at manufacture for military use, with up to 5000 hours life expectancy and printed with an additional code (Cyrillic 6Н3П-ЕВ). The rest were for domestic use, and with the ability to operate at over 200Mhz, the 6N3P was used in many East European VHF radios, televisions and in several beautiful radiograms in the 1950s and 1960s. The basic, domestic quality thermionic tubes have codes for a projected life span of either 1500 (6Н3П-Е) or only 500 hours (6Н3П). Many were used and then stored for over 50 years, so life expectancy may be questionable, both for the tubes and for me! The Tube Computer integrates 920 thermionic triodes in 460 tubes with 5 Backplane boards into a functional general purpose computer. It is still a work in progress, and it does need a lot of tweeking. But that's half the fun!!
I have written about why I built it and my many failures along the way and other stuff at: https://www.thetubecomputer.com/
All the tecky stuff is on the second page along with the new instruction set.
With vacuum tubes they warm up, start to work and then drift. Each tube drifts and so the whole system drifts. It takes quite a while to stabilise. I have set up all the tubes so that they hopefully become active NOR gates after a few minutes. This is when the tweeking begins. After each switch on a few tubes need to be adjusted to work as NOR gates and that's why there is so much monitoring
I am currently trying to improve stability of the entire system by redesigning the clock system and adding it to the bottom of the computer. Tests have gone well, and I hope to soon have a much more stable system requiring far less tweeking!
  • 460 × 6N3P Dual Triode Vacuum Tubes
  • 1840 × 1N33A point contact germanium diodes
  • 2300 × Resistors 1M,110k,51k,1k 0.1 w
  • 460 × Trimmer potentiometers 220k 0.5w
  • 460 × Capacitors ceramic 100nF 200v
View all 7 components
  • Retrocomputing Contest 25 October 2026
    Mike • 10/25/2026 at 19:03 • 0 comments
    It’s half term and the grandchildren arrive tomorrow. My weekend of soldering is over, and the main build is done, but sadly it is not finished, and I had to pinch the tube boards from bits 6 and 7 (in the middle of the picture) for the clock system (at the bottom) as I ran out of time and tubes!
    I have only been able to test the system by manually pulsing the binary counters as there is a fault somewhere between the oscillator and the first counter.
    The old clock design was a bit critical and needed to be set up carefully, but the new binary counters all worked first time without any tweeking at all! So for me, that’s real progress.
    On each switch on of the tube computer, as all the registers settle down, the new image display canvas receives a lot of random outputs from the computer and fortunately it has illuminated a few pixels, so that bit probably works.
    Once the extra tubes have arrived from Ukraine I’ll hopefully sort out the remaining problems and update both here at Hackaday and at thetubecomputer.com website later in November.
    I do find videos really difficult, what to say and how to say it. My last one got hammered on facebook for it's technical quality, apparently I made it round the wrong way! But still over 38,000 have looked at it, maybe just to agree! I shall make a new one, only this time I will look at others to see how it is done in the correct format!
    I did my very best in my time available for the contest, but my grandchildren do come first. My one piece of really good news is that over the whole weekend of soldering I only burnt myself twice, and not even worth a plaster!  Really good news!
    Kind regards Mike.
  • Retrocomputing Contest 23 October 2026
    Mike • 10/23/2026 at 09:06 • 0 comments
    The backplane boards are essentially passive, but I should have explained that my design for the 4 horizontal link boards is that they have a group of links to select the correct data bit for a pair of register backplane boards. The vertical extension boards are totally passive and simply carry the control signals, address, and data buses vertically to the link boards.
    The clock board at the bottom is used twice. Each side is used individually. A to D on the left for two binary counters and E to H on the right for the third binary counter, a very slow oscillator, and RAM buffers. I simply I ran out of room in the design to vertically install a single board. A clock cable links the two boards so hopefully they will act as one. We shall soon see if the idea works!
    With lots of design changes the new vacuum tube computer should drift less than the old, and with the new clock system it should need less tweeking. Hopefully it should also run the old programs with a minimum of modifications, as I have only altered 4 instructions.
    It should still output to the mechanical display, but also, I hope in future to link it to a “graphical” display I recently built. Not quite 8k UHD, only 16x32, but something it can draw on. Should be fun!
    I now have a whole weekend without any grand children, so I can build the new backplane boards, nothing too clever, it is simply a lot of soldering. But the old vacuum tube computer has to be removed from the wall to make way for the new. Oh dear!
    This is 2bits of the new backplane boards as they should appear on the wall, eventually!
  • Retrocomputing Contest 21 October 2026
    Mike • 10/21/2026 at 10:17 • 0 comments
    This month I have attempted to redesign the tube computer so that each bit is individually located on the acrylic panel with its own Accumulator, Program counter, Arithmetic logic unit, Memory address register and Memory buffer register. The first 4 bits will also have the Instruction registers. All the microcode, instruction decoders, input and output buffers, oscillators, external RAM buffers, binary counters and carry 7 stuff will be located separately at the bottom.
    My idea is that it could become a 16 or 32 bit vacuum tube computer. It would just need a wider data bus and room to keep adding bits to the top!
    As a kit it could also be built as a 2 or 3 bits vacuum tube computer with a restricted instruction set. Far cheaper, simpler and quicker to build. But then could be easily converted to a full 8 bit computer without changing any boards and just adding bits when time and funds allowed. At present it takes around a month to get spare 6N3P second hand vacuum tubes from Ukraine, and Polish supplies seem to have dried up.
    Earlier this month I designed and ordered new back plane boards to reconfigure the vacuum tube computer. I have also added a few buffers to reduce the amount of tweeking necessary to set everything up.
    This is the tube computer layout that I intend to build.
View all 3 project logs
  • 1
    Build Concept
    At the bottom of the website's first page I attempt to describe the concepts behind how I designed and built The Tube Computer, but I have not written a "how I did it" list. I am going to rebuild the website this winter with far more technical stuff on the second page which hopefully will cover it.
    And just a thought. If DigiKey could do a component kit, colleges could print the tube boards and combine them as a project to teach manual soldering to students. The colleges could build a DigiKey Vacuum Tube Computer in a day!
View all instructions
Nils Hoffmann wrote 10/20/2026 at 18:24 • point
I don't know why anybody would want to build this ... but I'm glad you did, amazing project!  And funny website xD
Mike wrote 10/21/2026 at 10:28 • point
Thanks Nils. You're right, it still seems like a daft idea to me, but I am also glad I did it!
Peabody1929 wrote 10/03/2026 at 17:25 • point
Check out the IBM 704 or 709 vacuum tube computers at the Computer History Museum in Mountain View, CA.  They have a clam shell design.  I have been inside them.  On the outside there is a "wall" of vacuum tube modules behind clear, plastic sheets.  On the inside there is yellow wire connecting the modules.  I think the tubes are on the outside so one can see any that have failed.
Mike wrote 09/25/2026 at 13:46 • point
Again thanks Arnauld c. Sorry I had left the old Instruction set from my previous vacuum tube computer! I have updated it now!
Mike wrote 09/25/2026 at 13:05 • point
Thanks Arnauld c. You are quite right it is an ultra secret instruction! I will amend the website text
arnauld.c wrote 09/22/2026 at 16:16 • point
Nice project! I'm a bit curious: on your website, you say there are 16 instructions, but only enumerate 15 of them (LOADA, LOADB, STOREA, STOREB, JUMPØ, GOTO, INPUT, OUTPUT, STATUS, ADD, XNOR, INC, NOT, CARRY and ADDC). So is the 16th one just some kind of NOP, or an ultra-secret instruction to take over the world? :-)
Paul McClay wrote 09/09/2026 at 17:42 • point
Your writeup... I don't know what to say. Except to let you know that someone read it.
Mike wrote 09/14/2026 at 06:39 • point
Thank you, I did wonder if I was writing the website to myself!
And thank you for looking at it.
