I have written about why I built it and my many failures along the way and other stuff at: https://www.thetubecomputer.com/
All the tecky stuff is on the second page along with the new instruction set.
With vacuum tubes they warm up, start to work and then drift. Each tube drifts and so the whole system drifts. It takes quite a while to stabilise. I have set up all the tubes so that they hopefully become active NOR gates after a few minutes. This is when the tweeking begins. After each switch on a few tubes need to be adjusted to work as NOR gates and that's why there is so much monitoring
I am currently trying to improve stability of the entire system by redesigning the clock system and adding it to the bottom of the computer. Tests have gone well, and I hope to soon have a much more stable system requiring far less tweeking!
Mike
This is 2bits of the new backplane boards as they should appear on the wall, eventually!
Charlie Smith
James Ots
Dave's Dev Lab
Kim Chemnitz Chemnitz
I don't know why anybody would want to build this ... but I'm glad you did, amazing project! And funny website xD
