Rev 2 Boards Arrived
A project log for EEEmu SPI
25MHz 1.8-5V SPI EEPROM/Flash Emulator
bleckyBlecky 06/11/2017 at 10:120 Comments
The Rev.02 EEEmu boards have arrived. The boards are looking pretty full, but they are the same size (51.5x20mm) and still have single sided component placement to make manufacturing easier.
The Rev.02 boards have quite a few changes:
These should be made up shortly. The only change before production for this board is to swap the USB footprint for the new connectors.
