Fennec started because every SI4732 radio project I looked at did the exact same thing. Small screen, a dial, maybe an encoder. Fine radios. All of them stopping at "tune and listen."
I wanted mine to actually do something with what it hears. Pull pictures out of shortwave. Read Morse off the air. Point me toward a transmitter using nothing but a signal meter and my own two feet. This post is the complete rundown. Hardware, flashing, every tool, and what's still coming.
🔩 The Hardware
At the center is the SI4732-A10, talking to the main chip over I2C. It covers long wave and medium wave from 153kHz up through 27.9MHz on AM, and 64 to 108MHz on FM. That's the whole broadcast world, plus amateur shortwave stretches and CB. It doesn't do airband, weather radio, VHF, UHF, or anything above 28MHz, that's outside what this chip was built for.
Running everything is an ESP32-S3, handling the UI, all five decoder tools, and the web server, all at once.
The full GPIO map is in the repo. One pin worth calling out specifically: GPIO1 taps the SI4732's audio output straight into the ADC. Without that wired in, RADIO still works fine, but SSTV and Morse have nothing to decode from the tuner, you'd have to fall back to the mic instead.
⚡ Flashing the Firmware
Install Arduino IDE, then add the ESP32 boards package, version 2.0.10 specifically. This project does not compile on the 3.x core.
Set the board to ESP32S3 Dev Module. Install three libraries: PU2CLR SI4735, TFT_eSPI, and XPT2046_Touchscreen.
One step that's easy to miss: copy User_Setup.h from the repo's docs folder into your TFT_eSPI library folder, replacing the default. Skip this and the display won't work.
Open the sketch, the folder needs to be named exactly Fennec or Arduino IDE won't find it, select your board, upload. If you don't have the radio hardware wired up yet, there's a simulate-radio flag in Config.h that brings up the full interface with no SI4732 connected at all.
📻 Radio
Straightforward AM, FM, and shortwave listening. Band tabs at the top, with shortcuts underneath for specific ranges: full shortwave span, Japan FM, the 49-meter broadcast band. SEEK hunts the next station, MUTE cuts the speaker, RDS pulls station name and program info where it's broadcast on FM.
Close it and come back tomorrow, band, frequency, and volume are all saved to flash.
🖼️ SSTV
Shortwave still carries images. Slow-scan television, a tone that draws a picture line by line.
Open SSTV, and Fennec switches to USB or LSB, listens for the VIS header that identifies the format, and starts drawing. Supports Martin, Scottie, and Robot 36, leave it on AUTO or lock a mode if you already know what's incoming.
Feed it from the tuner, or switch to the mic and hold a speaker up to it. In mic mode the amp mutes automatically so Fennec isn't decoding its own output. There's a BFO nudge if the picture comes in wrong, and the decoded image sticks around even if you back out of the screen.
📟 Morse
Listens for CW and prints what it hears as text. Set the pitch to match the tone, pick USB or LSB, nudge the BFO if the note isn't centered.
It waits through the first word to estimate sending speed, then starts printing continuously. Built for casual copy, roughly 15-30 words per minute, not contest-grade, but solid for pulling readable text off a clean shortwave signal.
🧭 Homing
Not a compass bearing, a signal-strength peak. Open HOMING and you get a live sparkline, about eight seconds of RSSI history, with the onboard LEDs pulsing brighter as signal gets stronger. Turn a directional antenna, walk, and watch for where the trace climbs.
Needs a directional antenna, not a plain whip. A whip picks up roughly the same strength from every direction. You're the motor, Fennec is the meter.
👁️ Watch
An unattended activity logger for a specific frequency. Park on it, arm it, and Fennec watches the carrier. Every time it holds above your threshold, it logs the event: timestamp, frequency, peak strength, up to 32 events, saved to flash.
Set it before bed, check it in the morning. This is a listener's tool for noticing when something comes on air, not a decoder of voice content.
🌐 Web Remote
Fennec also runs as its own WiFi access point, SSID "Fennec." Connect, open a browser to 192.168.4.1, and the web page mirrors the device in real time. Change a tab on your phone, the physical screen follows, and back. Only one tool runs at a time either way.
Point it at your home WiFi in settings and it'll also pull time over NTP for a live clock in the header. There's a full JSON API behind it too, for anyone who wants to script tuning, band, volume, or pull live SSTV frames over plain HTTP.
❗ Troubleshooting
White or garbled screen. Almost always the User_Setup.h swap. Make sure it's copied from the repo's docs folder and matches your GPIO map.
Touch not responding right. Hold OK while booting to enter touch calibration.
Loud thump when the amp turns on. Check the amp shutdown pin polarity matches your wiring.
One LED stuck bright green. RMT memory allocation issue. Use RMT_MEM_128, not RMT_MEM_64, and stay on core 2.0.10.
SSTV says no audio. Confirm the analog tap from LOUT to GPIO1 is actually wired, or switch source to MIC.
Compile errors around RMT. You're on core 3.x. Roll back to 2.0.10.
🧡 Sponsored by NextPCB
Thanks to NextPCB for supporting this build. If you're making your own Fennec, the Gerbers are in the GitHub repo, upload the zip, default settings work fine. www.nextpcb.com
Gerber files are in the GitHub repo. I use NextPCB upload the zip, default settings work fine, five boards cost just a few dollars and arrive in under two weeks. Order from NextPCB
💻 Code and Files
Everything's open source under the MIT license: firmware, schematics, and docs, all on GitHub.
GitHub: github.com/cifertech/Fennec
🚀 Final Thoughts
Five listening tools on one open-source board, built around a chip that was only ever meant to do broadcast radio. There's still more coming, a few things are already on the list for a v2 revision.
If you build one, share it. If you find a bug, open an issue. If you want to add something, open a discussion first.
That's all for this one.
