Third prototype dual module
09/05/2026 at 09:47 • 0 commentsThe third prototype had the fully functional 2 balls with a solid base to test all the functions but aesthetically it was very boring. So in the next version I redesigned the base
Second prototype
09/05/2026 at 09:28 • 0 commentsThe second prototype was a lot smoother and a small motor was able to turn the ball
First prototype
09/05/2026 at 09:26 • 0 commentsThe first prototype of the mechanism. The first print was very rough and had a lot of friction. After this I added bearing on both shafts and made it a lot more smoother so that small motors could drive the balls
initial concept
09/05/2026 at 09:24 • 0 commentsinitial concept of the mechanism to figure out the movement
