​Time for the firs tests.
A project log for Web Enabled Led Matrix
Not just any Led matrix you've seen... You can play Retro Games like Pong from anywhere in the world with your phone.
cabattistacaBattista • 06/10/2017 at 09:44•0 Comments
The firs scetces I did were simple one liner color set methods.
I tried diferent colors and brightnesses to see how bright it would be with just the usb power.
In theory each led uses 100mA, I have 200 leds wich equates to 30A! of power usage. So I will ad a bigger power supply later.
Old Pc power supplies are great for this application as they can proivide up to about 40A on the 5V rail.
