Livyatan Design Suite: Project Cancellation
Mothballed
Livyatan was a suite of local-first, AI-built design and fabrication tools, free for individuals and small shops. Apparently no one is interested due to the bad reputation of AI generated software. Since launch, interest has been close to zero.
So the project is being diverted. Development continues, but only as my own in-house workflow at the shop. There will be no more public releases, downloads, repos or roadmap, and the old links have been taken down.
Anything you already downloaded is yours to keep under its original license. It runs on your own hardware with no account and nothing phoning home, so it won't stop working.
Thanks to everyone who took a look.
WHAT IT IS
Livyatan is an integrated design suite for makers, built over the past year by one CNC machinist working nights and weekends. CAD with shop export, image generation, image-to-mesh, artwork-to-cut, a toolpath viewer, resin print prep, a machining advisor, and more — eighteen modules and counting.
They are separate programs that talk to each other through ordinary files. Written in Rust. The core runs on any Debian box with no GPU and no network connection. No subscription, no account, nothing phones home. Free — PolyForm Small Business 1.0.0.
OUT NOW — five modules, all pre-beta
Structor 0.11.1 — a solid modeller for print-and-cut parts. Primitives, weld, group, measure, STL in and out, save/open/recent with autosave. The build plate sits inside a modelled 30 m shop bay with a granite inspection bench and a bridge crane overhead, because the viewport is a game engine rather than a CAD widget. Runs on any Debian box, no GPU.
Phantasos 0.3.1 — image generation on your own GPU (Vulkan; AMD, Intel, NVIDIA), or on a GPU box across the LAN with one button. Prompt it, or hand it a picture and say what to change. While it renders, an hourglass runs sand paced to the time your particular machine actually takes.
GilgaMESH 0.2.1 — photograph to sliceable STL at the size you name. Rotate and crop before you commit. Mesh generation wants about 8 GB of GPU memory or a large unified-memory box; repairing a mesh needs no GPU at all.
Glyptica 0.1.2 — glyphs into matter. Photograph a drawing, a rubbing, a page of lettering. It flattens the page, lifts the linework off the paper, lets you clean and place it, and hands you two things a machine can make: SVG cut lines for a laser or plasma, and a carved STL in the artwork's own shape, intaglio or emboss, ready to print or to boolean onto a part in Structor. Any Debian box, no GPU.
Nazca 0.1.2 — the viewer. Load the G-code your CAM wrote or the .ctb your slicer packed and walk the job in 3D before any iron moves or resin cures. It works out what machine the file is for, colours every move by what it does, and scrubs it layer by layer. It reads; it never writes.
All five ship as working test prototypes with their rough edges written into the release notes rather than hidden. Every window sizes itself to the monitor it opens on.
Downloads: https://github.com/3DJ77/Livyatan — Debian 13 / Ubuntu 24.04+ — sudo apt install ./structor_0.11.1_amd64.deb
THE OBELISK
A design suite is easy to demo and hard to prove. Any single module can be made to look competent in a screenshot. What cannot be faked is one object going the whole length of the chain and coming out the far end as a part you can hold.
So I picked the most boring object I could think of. Flat faces, hard edges, a taper, and a carved face — enough geometry to catch real errors, simple enough that when something comes back wrong I can see which stage caused it. A dragon hides its defects in the scales; an obelisk has nowhere to put them.
The glyphs are mine: five sigils drawn in pencil almost thirty years ago, on paper that barely survived. The path from that page to a printed monument is idea → drawing → photograph → flatten → lift the linework → clean and place → carve → weld watertight → slice → walk the toolpath → print. With Glyptica and Nazca out, every...
  • Project diverted: Livyatan is mothballed
    Jeremiah • 10/14/2026 at 14:30 • 0 comments
  • Two more off the wall — Glyptica and Nazca
    Jeremiah • 09/13/2026 at 04:24 • 0 comments
    Log #1 said the scanner was next. It still is. What surfaced first is the pair that sat
    upstream and downstream of everything in that first log without their own names on the
    page.
    **Glyptica** is the module that turned a thirty-year-old pencil drawing into the sigils on
    the Obelisk. Photograph a page, click its four corners and it un-warps flat, the
    linework comes off the paper, you clean it and place it, and it hands you two things a
    machine can make: SVG linework for a laser or plasma cutter, and a carved STL in the
    artwork's own shape, intaglio or emboss, ready to print or to boolean onto a part in Structor. Named
    for
    glyptics, the old art of cutting figures into stone. Any Debian box, no GPU.
    **Nazca** is the viewer. Load the G-code your CAM wrote or the .ctb your slicer packed and
    walk the path in 3D before any iron moves or resin cures. It reads the file to tell
    what machine it's for, printer, router, laser or plasma, and colours every move by what
    it does: travel, cut, plunge, pierce, extrude, retract. Scrub by layer or by move, hide a
    class, play it through. Sliced resin files scrub and play layer by layer too, with a stack
    view that grows the print under the camera. It reads; it never writes.
    Named for the lines on the Peruvian plain that people walked as preparation.
    Both ship the way GilgaMESH did: working test prototypes with the rough edges in the
    release notes rather than hidden. Glyptica's photo detection is a mid-tone heuristic, so
    a very dark or very light page may need the Invert switch; its slab is flat, and curved
    faces are Structor's boolean job. Nazca walks G0 to G3 with arcs and doesn't simulate
    offset or incremental dialect codes, so a file leaning on those won't preview true.
    Both are pre-beta and may have issues. Say what breaks.
    Same night, all five modules got a reroll: one palette across the suite, and every
    window now sizes itself to the monitor it opens on. The 0.1.0 debs came up tiny on a 4K
    screen; that's fixed.
    With these two, the whole Obelisk path now runs on modules you can download. Dropping
    them together was deliberate: it clears the deck for Gorgon, the scanner, which needs
    more work than either of these did. No date on it.
    **Next log:** the scanner, when it earns it.
    Gallery: https://g54xyz0.com · Releases: https://github.com/3DJ77/Livyatan ·
    Glyptica: https://github.com/3DJ77/Livyatan/releases/tag/glyptica-v0.1.2" class="redactor-linkify-object">https://github.com/3DJ77/Livyatan/releases/tag/glyptica-v0.1.2 · Nazca: https://github.com
    3DJ77/Livyatan/releases/tag/nazca-v0.1.2 · Pages: https://g54xyz0.com/m/glyptica.html · https:/
    g54xyz0.com/m/nazca.html
  • The suite got a home
    Jeremiah • 09/12/2026 at 16:57 • 0 comments
    Log #1 promised the scanner next. The scanner is still on the bench. What happened
    instead this week is less photogenic and matters more: the project stopped renting
    its own front door.
    Until now the wall lived on a GitHub subdomain, the newsletter signup handed
    addresses to a third-party service, and the visitor counter was somebody else's
    script. For a suite whose whole pitch is *your hardware, your files, no accounts*,
    that was a contradiction I'd been ignoring because the parts were free.
    So: **g54xyz0.com** is the address now. The name is a machinist's pun — G54 XYZ0 is
    the line that sets the work origin, the point everything else is measured from.
    *Start here.* The old links redirect, nothing you've bookmarked breaks.
    Behind it, three things moved onto a box in my shop in North Anson, Maine:
    - **The Herald**, the release newsletter, is now a small program I wrote that runs on
    my own machine — subscribers in a file I own, sent through mail I control. Nobody
    upstream gets to decide whether it goes out. The first issue is out now.
    - **The visitor counter** is self-hosted, first-party, no cookies. It counts pages,
    not people.
    - **The signup form** on the wall posts straight to that box. There is no service in
    the middle.
    None of this is a module — you can't download it. But it's the same idea the modules
    are built on, applied to the project's own internal infrastructure, and I didn't want to ask anyone
    to trust the first while the second phoned home.
    Also since log #1: the obelisk is on Printables twice — the calibration blanks under
    CC BY so you can carve your own marks into them, and the glyph obelisk as its own
    model. Both print support-free.
    **Next log:** still the scanner. It's closer.
    Blanks: https://www.printables.com/model/1833053-the-obelisk-calibration-models
  • The obelisk is the yardstick
    Jeremiah • 09/06/2026 at 13:02 • 0 comments
    The Obeliisk
    The 3D printed proof
    Model on the plate in Structor
    Editable in suite
    Watertight STL
    The results.
    A design suite is easy to demo and hard to prove. You can screenshot any one module
    looking competent. What you can't fake is one object going the whole length of the
    So I picked the most boring object I could think of — an obelisk. Flat faces, hard
    edges, a taper, a carved face. Enough geometry to catch real errors, simple enough
    that when something comes back wrong I can see which stage did it. A dragon hides its
    The glyphs are mine. Five sigils I drew in pencil almost thirty years ago, on paper
    that barely survived. The path from that page to a monument on the bench:
      idea → hand drawing → photograph → rectify the page → extract the linework as a
      mask → clean and place it on the stone face → emboss → weld watertight → slicer →
      print
    Over the past week or so I've had that running the whole way through, to slicing and
    to a printed object I can hold: Ender-3 Max, 0.2 mm, about two and a half hours,
    galaxy black PLA. The weld stage returned one watertight body.
    Three of those stages ship today. Structor built the obelisk body. GilgaMESH did the
    weld — `gilgamesh remesh`, a voxel remesh that resolves the carve and the body into a
    single watertight solid, which is what makes it sliceable rather than merely
    correct-looking. The rectify, extract and emboss stages are Nazca, which unveils later
    in the rollout.
    What the obelisk is *for* is the part I care about. It's a recurring calibration and
    first-test project: every module gets measured against the same object, every new
    module joins the run, and anyone learning the suite can walk the identical path
    instead of starting cold on their own hard part.
    Next log: closing the loop. Gorgon is a handheld 3D scanner I'm building so the
    printed obelisk can be scanned back into a model and compared against the one that
    went to the slicer. That's the step that turns this from a walkthrough into a
    fidelity measurement — a number for what each stage of the chain actually costs you.
    It's on the bench now, not shipped.
    Gallery: https://3dj77.github.io
View all 4 project logs
