Food Manager
In over 60 years daily global wasted food is only getting worse...
let's make it smart!
Every year, consumers in industrialized countries waste almost as much food as the entire net food production of sub-Saharan Africa (222 million vs. 230 million tons). The wasted food comes mostly from houses where it expired. Expiry of food is a reality and it should not be a problem. It should be easily managed.
In industrialized contries very often the customers buy too many products. The surplus products are trashed, or lead customers to obesity. The problem begins with the customers. They doesn't have the needed knowledge to do a responsible and healthy shopping most of the time.
Food Manager is a system that aims to drastically reduce food waste. I already personally tested the principles and some devices at the base of Food Manager. The results are quite shoking: my family monthly expenditures on food are reduced by 30% and the food waste is almost to zero.
sasha.ant111 wrote 05/27/2024 at 20:42 point
Hi. I have been playing on this site for a long time in Bangladesh, because there are many different interesting online games that I really like. I recommend you to try it too, because you can easily register on this site and enjoy playing quality slot machines - https://jeetbuzzbd.com/ . Good luck!!!
