Project Ceylon: What If the Amiga Never Died?
What if Commodore had never gone bankrupt and Amiga development had never stopped?
Public Chat
What if Commodore had survived and the Amiga had continued evolving for another 30 years? Project Ceylon is an independent attempt to build one plausible answer: a modern x86-64 microkernel workstation that carries forward the Amiga’s emphasis on responsiveness, multimedia, specialized subsystems, and a coherent machine/OS design—without reproducing 1980s hardware. Ceylon is not an Amiga emulator or museum reconstruction; it is an alternate-history engineering experiment asking which Amiga principles remain valuable on a modern machine. Ceylon already boots and runs under QEMU. Core platform mechanisms, storage, IPC, shared memory, scheduling, protection domains, and major portions of the device/service architecture are working. Graphics, audio, networking, recovery, the desktop, NuDOS and NuBASIC are being integrated toward the first externally testable A-series alpha. The first alpha will go through a small curated technical evaluation before a broader public QEMU release
What If the Amiga Never Died? One Engineer Is Building the Answer
Commodore went bankrupt in 1994. Continuous Amiga development stopped with it. Project Ceylon starts with a simple alternate-history question: what would that machine have become if it had kept evolving for another thirty years?
Mike, the sole developer, is clear that this is not an emulator, not a museum piece, and not a 68000 recreation. It is a modern x86-64 microkernel workstation that tries to carry forward the Amiga’s actual useful ideas—responsiveness, multimedia treated as a first-class citizen, specialized subsystems, and a coherent relationship between the machine and its software—without reproducing 1980s hardware. The project lives on Hackaday.io and already boots under QEMU.
From Media Workstation to Operating System
The work did not begin as an operating system. It started as a media workstation idea. At some point the requirements for graphics infrastructure, audio, a desktop, and applications forced a harder admission: the project was no longer building a workstation on top of someone else’s computer. It was building the computer underneath the workstation.
Early on, Mike made a deliberate choice to stay QEMU-first. Defining a reference machine (Q35 chipset, IOMMU, VirtIO devices, Intel HDA) means the same hardware questions can be asked repeatedly while the software evolves. The A-series is the virtual line. The later B-series is intended for certified physical hardware. Nothing QEMU-specific is supposed to leak into the parts that bare metal will eventually replace.
Static Foundations, Dynamic Systems
Ceylon’s architectural identity is unusually explicit for a solo project at this stage:
  • Capability-based authority
  • Isolation by default
  • Bounded resources
  • Generation-safe reuse
  • Small control messages with shared bulk-data paths
  • Predictable behavior where real-time matters
  • Hardware-shaped interfaces that can move from virtualization to bare metal
Rather than making the foundation behave like a conventional desktop OS, the project provisions resources deliberately and builds dynamic behavior above them. A bounded pool of isolated execution workers is created ahead of time; applications lease them. Workers move through a lifecycle (FREE → LEASED → ACTIVE → QUIESCING → RESETTING → FREE) with generation counters so stale references are rejected. Multiple isolated workers can participate in one logical application environment while retaining separate protection domains. Sharing memory does not automatically mean sharing authority.
Virtual memory follows the same pattern. Bounded virtual-address capacity is preconstructed; mappings inside those arenas can still be dynamic. The memory manager receives carefully limited page capabilities rather than unrestricted kernel authority. Early stress testing has included four isolated workers sharing a physical page with pointer transparency, 10,000 lifecycle cycles, and hundreds of thousands of randomized operations with zero resource drift in the tested scope.
The underlying microkernel was upgraded during the project. That migration invalidated some earlier assumptions and forced a careful return to a known-good, reproducible baseline. Multiprocessor support, IOMMU operation, PCI enumeration, USB, storage, networking, and the display path all came up on the new foundation. Isolation testing covered DMA, interrupts, and floating-point state. The logs repeatedly emphasize measuring first, freezing baselines, and refusing to call something done until it has been proven under the current source.
Where It Stands Now
As of mid-October 2026, Ceylon boots to a graphical desktop under QEMU. It accepts keyboard and mouse input and runs native application code. Asteroids has exercised the full install-launch-input-draw path. Terminal and NuDOS communicate through a separate shell service. The compositor (Iris) has been integrated and tested for multiple clients, presentation, application isolation, invalid requests,...
that just turned out nice.
Portable Network Graphics (PNG) - 2.31 MB - 09/29/2026 at 03:47
Preview
Actual Project Ceylon runtime capture from QEMU. Early “first light” framebuffer output during bring-up. This is not a UI mock-up or rendered concept image; it is output produced by the Ceylon system during development. The incomplete text rendering visible here reflects the state of the display path at that milestone.
Portable Network Graphics (PNG) - 40.93 kB - 09/19/2026 at 22:18
Preview
Project Ceylon Architecture
Portable Network Graphics (PNG) - 2.12 MB - 09/19/2026 at 21:32
Preview
Current Progress and Roadmap
Portable Network Graphics (PNG) - 2.05 MB - 09/19/2026 at 21:30
Preview
  • 1 × Target virtual platform: QEMU, Q35 chipset
  • 1 × IOMMU enabled
  • 1 × xHCI USB controller
  • 1 × VirtIO block and network devices
  • 1 × Intel HDA audio device (intel-hda)
View all 7 components
  • Project Ceylon Development Log - October 24, 2026: Slowing Down on Purpose
    Mike • 6 days ago • 0 comments
    I'm sure there's not too many of you out there waiting with baited breath on my next words, but I do try to be consistent.  It’s been a couple of weeks since I’ve done a proper Ceylon update, and the pace has changed a little.
    That’s deliberate.
    For a good part of this project, progress meant building things that simply didn’t exist yet: getting the machine booting, putting graphics on the screen, making storage work, building a desktop, and eventually reaching the point where an actual application could launch and do something useful.
    There are enough pieces in place now that adding another new subsystem isn’t always the most useful thing I can do.
    Lately I’ve been spending more time going back through the machine, fixing known problems, tightening up things that were good enough to move forward earlier, and making sure the stuff that already exists actually behaves the way I think it does.
    That’s less flashy, but it’s also probably a sign that this thing is becoming a computer.
    The Desktop Is Getting Less Theoretical
    A lot of the recent work has been around NuGUI and the compositor—the part of the desktop responsible for deciding what gets drawn, where windows live, and who owns things like pointer and presentation behavior.
    Several pieces of that work have now passed their individual checks, including pointer ownership, application-window handling, visual treatment and display-mode work.
    That does not mean I’m declaring the whole desktop finished. I’m being much more careful about that distinction these days. One exact-candidate test run passed 819 tests with zero failures, and the project still correctly remained short of whole-product qualification.
    Apparently “819 tests passed” and “everything works” are two different sentences.
    Who knew?
    NuDOS Taught Me a New Word: gdkz
    NuDOS has also been getting real target testing.
    One of the better bugs from the last couple of weeks came from a wonderfully simple test. We typed ECHO, and the machine responded with gdkz.
    That turned out not to be some deep shell-parser catastrophe. The keyboard mapping was simply wrong for most of the alphabet.
    The mapping was corrected, and some related focus/input problems were also closed out with target evidence. We also confirmed something every desktop user already knows instinctively: if you want the Terminal to receive the keyboard, you should probably give the Terminal keyboard focus first.
    Again, normal computer behavior. Built the hard way.
    Some NuDOS operations still report that they’re unsupported because the filesystem underneath them does not yet provide those operations. That is intentional. I would rather have the shell tell the truth than fake success because it makes a test report look nicer.
    The Display Bug Was Not Where I Expected It to Be
    One of the more interesting problems involved the virtual display hardware.
    At first, the temptation was to fix the PCI layout directly. We tried that, discovered it was the wrong approach, and backed it out.
    What eventually made the problem understandable was a controlled comparison of two otherwise similar virtual machines. Changing whether one virtual network device existed changed where the firmware placed the display device’s register window.
    One device changed the memory layout of another device.
    That explained why the same display assumptions worked in one QEMU profile and failed in another.
    Once the measured hardware profile was represented correctly, the display-mode qualification passed. Naturally, fixing that exposed the next problem farther down the presentation path.
    Operating systems are very considerate that way. They rarely let you run out of things to do.
    Ceres Is Becoming a Useful Nuisance
    Ceres Rock Battle has taken over the role Asteroids had earlier in development: small enough to understand, complicated enough to expose almost everything that's wrong.
    Getting it into...
  • Project Ceylon Development Log — October 24, 2026: Sometimes the Project Has to Wait
    Mike • 10/25/2026 at 04:20 • 0 comments
    It has been quiet for about a week. Life needed the time, so Ceylon waited.
    I’m picking it back up in the next few days. The foundation is in a better place than it was a few weeks ago, which means the next real work sits higher in the stack.
    Next focus: the interface
    The main block is NuGUI. We already have the skeleton. What it needs now is the ordinary primitive set that real applications actually depend on — controls, layout, text, panels, menus, window behavior, focus, and basic lifecycle handling. The goal is no longer “a window can appear.” It is “an application can live in this environment without constant special cases.”
    Workpad is part of that. It is a visible, dockable sidecar clipboard. Not a replacement for ordinary copy/paste, just a persistent place to keep material (text, files, references) while moving between applications. For Alpha it stays deliberately modest: visible, dockable, useful. Nothing clever.
    Iris needs another pass as well. The presentation path has improved, but it still carries assumptions that were acceptable when the goal was simply putting something on the screen. Those assumptions need to be cleaned up before we start expecting several real applications to share the display for extended periods.
    There is also some storage and memory tightening to do. Nothing architectural — just making sure the platform’s actual behavior matches what the GUI and application layers are about to assume.
    What this is aiming at
    Once NuGUI, the remaining Iris work, and the audio path are in better shape, the next useful step is a small set of basic applications used together: create something in one, save it, find it in another, reopen it later, move information between tools, restart the machine, and see whether the whole thing still agrees with itself. That is the testing I want next.
    Posting
    I’m also dropping the near-daily log habit. The work continues, and I will keep documenting it, but I would rather write when a coherent piece of work has actually landed than force every session into its own entry. Some weeks that may mean one post. Other times it may mean combining several days into a single log that tells the story more clearly.
    The direction has not changed. The next tranche is defined. I’m ready to get back to it.
  • Project Ceylon — State of the Machine, October 18, 2026
    Mike • 10/19/2026 at 01:10 • 0 comments
    October 18, 2026
    Ceylon boots to a graphical desktop, accepts keyboard and mouse input, and runs native application code. Asteroids has exercised the application path, while Terminal and NuDOS now communicate through a separate shell service. Close/reopen, clipboard, and recovery scenarios have passed their defined tests.
    The compositor work is integrated. Its testing covered multiple clients, presentation, application isolation, invalid requests, full queues, and recovery. Independent review also caught lifecycle defects that were repaired before acceptance. That gives us a stronger graphics foundation, although the complete NuGUI desktop is still unfinished. Audio also remains incomplete.
    Storage is the immediate priority. Workpad—the window-associated tray for keeping related material—has reached explicit retention and save testing, but reliable restoration after reboot is not yet qualified. That work exposed a real invalid-write defect and gaps between a write being accepted and its contents being durably committed.
    Those gaps are being addressed through filesystem coordination, journal/checkpoint work, device flush handling, and reboot controls. The latest target tests proved clock delivery, timeout handling, stale-response rejection, and several abort/retry behaviors. One final executor assertion still needs resolution. Those results do not yet establish durable Workpad recovery.
    The repeated build preparation problems have also been expensive. We have corrected the input catalog, dependency provenance, preflight checks, and logging so missing ingredients are caught before another lengthy build begins.
    The next goal is straightforward: finish dependable storage, complete Workpad and NuGUI, then test the integrated desktop with real applications. After that comes the broader service-boundary review and the remaining Alpha work.
    There is a working machine here. The job now is making its everyday behavior dependable enough to put in other people’s hands.
  • Project Ceylon Development Log — October 13, 2026: The Bug That Wasn't There Anymore
    Mike • 10/14/2026 at 16:39 • 0 comments
    Mike · October 13, 2026
    Tags: Project Ceylon, Operating Systems, Microkernel, Iris, NuGUI, Documentation, Build Systems
    Today was foundation day.
    Not the exciting kind. The kind where you prove the ground is actually solid before you put any weight on it.
    By the end of the session, Ceylon had a single canonical source line, a build that reproduces itself byte-for-byte from a clean seed, a regression suite that actually runs, and a performance baseline measured before anyone touched a single optimization.
    It also had a scope document — the full Alpha release, all seven workstreams, written down and adopted.
    And it had one bug that turned out not to be a bug at all, which is the part of today I actually want to write about.
    Measure First, Then Build
    Before any feature work, I wanted ground that wouldn't shift.
    That meant a governed seed for the build, checked six different ways: provenance, completeness, three fail-closed negative tests, and a full rebuild from scratch matched hash-for-hash against the reference image.
    Byte-identical.
    Not "close enough."
    Identical.
    It also meant establishing a performance baseline before any of it got touched.
    That is the part people skip. It is also the part that pays for itself immediately, because you cannot tell if something got faster later if you never wrote down how slow it was today.
    We Found a Process That Had Been Running for Six and a Half Hours
    While building that baseline, a verification pass flagged something that didn't belong.
    A monitoring loop, left over from an earlier measurement, was still running.
    Quietly.
    In the background.
    For six and a half hours.
    Nobody noticed because it wasn't failing anything. It was just sitting there, burning CPU and skewing whatever it touched, invisible until something actually checked.
    That is not a dramatic bug. It is not a design flaw. It is a background process somebody forgot to kill.
    But it's exactly the kind of thing that measurement catches and assumption doesn't.
    We killed it, wrote down why, and moved on.
    The rule that came out of it is simple: every measurement tool gets the same guaranteed teardown as everything else. Nothing gets to just sit there because nobody was looking.
    The Documentation Standard Got a Name
    Heathkit kits assumed nothing.
    Every step was numbered. Every step told you what you should see if it worked. The troubleshooting chart was organized by symptom, not by part number.
    Ceylon's documentation now follows that same discipline on purpose, not by accident.
    There's a user guide, a builder's guide, a theory-of-operation document per subsystem, and reference tables generated from the actual source rather than typed by hand — so they can't quietly drift out of sync with the code the way hand-written documentation always eventually does.
    We also found out exactly how far from that standard the current source sits.
    67 of 138 files still carry placeholder documentation headers.
    That number is going down, not up, as each tranche touches those files.
    It is not going down today.
    Today was just the day we measured it honestly instead of guessing.
    The Alpha Got a Shape
    With the ground settled, the scope for the first public release got written down and adopted.
    That includes the desktop and compositor, the DOS-style shell, the platform services underneath it, networking, audio, quality, release packaging, and documentation as its own cross-cutting workstream rather than an afterthought.
    The hardware plan is staged on purpose.
    The free Alpha runs under QEMU and is explicitly a proof of concept, not a performance demo.
    After that comes bare-metal hardware with CPU rendering.
    After that, GPU acceleration, built as a plug-in to the same contract rather than a rewrite.
    The rule that makes that staging possible is simple: nothing QEMU-specific is allowed to leak into the parts of the system that bare metal will eventually replace.
    That's slower to build correctly.
    It's also the only...
  • Project Ceylon Development Log — October 12, 2026: The Terminal Finally Came Back
    Mike • 10/14/2026 at 16:13 • 0 comments
    Mike · October 12, 2026
    Tags: Project Ceylon, Operating Systems, NuDOS, NuGUI, Terminal, Rust, Audio, Testing, Application Lifecycle
    Yesterday ended with one of those wonderfully specific operating-system problems:
    The Terminal could open.
    It could take input.
    Copy and paste worked.
    Closing it was the part that still wasn't trustworthy.
    Today we pushed that path harder.
    By the end of the session, NuDOS had made it through revoke recovery, real keyboard input, ordinary copy and paste, close, reopen, and the rest of the lifecycle path on the corrected machine profile.
    That is a much better place to be than we were twenty-four hours ago.
    It also came with a useful reminder that not every failure belongs to the product.
    Sometimes the test rig is the thing lying to you.
    We Found the "Bug" in the Runner
    One of the remaining NuDOS failures looked like a post-revoke keyboard problem.
    That was concerning because revoke/recovery behavior is exactly the sort of thing we are trying to prove before calling the desktop environment stable.
    The eventual root cause was not a production input defect.
    The qualification run had been using the wrong machine profile.
    Once the intended Q35/IOMMU/xHCI configuration was restored, the supposedly broken recovery path behaved correctly.
    Keyboard input after revoke passed.
    Ordinary copy and paste passed.
    Closing the Terminal passed.
    Opening it again passed.
    The session lifecycle passed.
    That result matters for more than just the Terminal.
    We have spent a lot of time lately making sure Ceylon's qualification process distinguishes between "the system failed" and "we did not actually test the system we thought we were testing."
    Those are very different conclusions.
    A bad runner configuration can waste hours if you trust the first screaming subsystem and start repairing it.
    So today was another case where the most useful debugging result was figuring out which layer was actually guilty.
    NuDOS Is Getting Close to the Interesting Part
    The NuDOS work has now moved well beyond "does the parser understand a command?"
    We have already been through command semantics, malformed input, clipboard behavior, application/session interaction, saturation, cancellation, revoke behavior, and recovery.
    Now the important paths are increasingly the ones that make the shell feel like part of the operating system rather than a library with a prompt attached to it.
    That means the Terminal has to survive the same lifecycle expectations as any other application.
    It has to open through the normal desktop path, interact with the system services it is entitled to use, shut down cleanly, give its resources back, and start again without inheriting stale state from the previous session.
    Today's R32 work proved that sequence on the corrected test configuration.
    That is significant.
    It is not the same thing as saying NuDOS is finished.
    There are still open qualification items, the final native adapter is not complete, and the full target session remains ahead.
    But the remaining problem set is getting smaller and much less mysterious.
    That is exactly where I wanted to get before integration work starts becoming expensive.
    The Audio Work Also Reached a Useful Boundary
    Audio continued moving in parallel, but under a very deliberate rule:
    do not let audio experimentation interfere with the NuDOS qualification work.
    The current audio prebuild has now reached a useful host-side checkpoint.
    The code compiles on the host.
    The host tests pass.
    The reference audio fixture passes.
    That includes the basic 48 kHz stereo path we wanted for the first round of validation.
    What did not happen today is just as important.
    We did not prove native Ceylon audio.
    The target-side build hit an offline toolchain dependency around the Rust build-standard-library path.
    The Aria/Lyra source reconciliation is still incomplete.
    Native HDA output was not run.
    Nothing was promoted into the canonical system image.
    That...
  • Project Ceylon Development Log — October 11, 2026: Copy, Paste, Close… Well, Two Out of Three
    Mike • 10/14/2026 at 16:04 • 0 comments
    Mike · October 11, 2026
    Tags: Project Ceylon, Operating Systems, NuDOS, Terminal, Rust, Audio, Compilers, Application Runtime, Testing
    Yesterday was one of those satisfying operating-system days where Asteroids finally started behaving less like a test payload and more like an application.
    Today was more shell-shaped.
    NuDOS continued moving toward the real Ceylon desktop, and by the end of the day we had ordinary copy and paste working through the intended path, the input regressions were still green, and the next failure had become wonderfully specific:
    we can open the Terminal. We can use it. We can copy and paste. We just can't close it and reliably open it again yet.
    Honestly, I'll take that.
    That is considerably better than "something somewhere doesn't work."
    NuDOS Is Starting to Meet the Rest of the Computer
    The portable NuDOS command engine has been coming together for a while, but the interesting work now is increasingly at the boundary between that engine and the actual Ceylon desktop.
    That means the boring-but-important stuff.
    Input has to arrive through the real semantic-input path. Output has to travel through the correct Terminal/session plumbing. Clipboard operations have to behave like desktop operations rather than test-harness tricks. Closing the Terminal has to tear down the application cleanly enough that the operating system can create another one afterward.
    Today the copy/publication path passed.
    Paste passed.
    The existing HID/input behavior survived the changes.
    That gives us another useful slice of normal desktop behavior rather than a synthetic test case.
    The Terminal can receive the user's input, interact with the clipboard, and continue through the normal application path without regressing the input work underneath it.
    The current problem is lifecycle.
    Closing the Terminal and bringing it back is still blocked.
    That is now the thing we are chasing.
    "Close the Window" Is Still Not a Small Request
    Yesterday Asteroids gave us a similar lesson.
    Running an application is one problem.
    Stopping one correctly is another.
    Stopping it and then proving the operating system can reuse everything afterward is where the lifecycle starts becoming interesting.
    The same applies to the Terminal.
    When the user closes it, several things have to agree about what just happened. The GUI has to issue the right close request. The application has to receive it through the supported lifecycle path. Its session attachments need to be retired correctly. Resources need to be returned. Stale state must stop being useful. Then a new Terminal instance has to start without inheriting pieces of the old one.
    If any one of those steps is incomplete, "close the window" becomes "close the window and discover an operating-system archaeology project."
    That is roughly where we are.
    The useful part is that the failure has moved toward the normal NuGUI close ingress rather than remaining some vague Terminal problem.
    So the next qualification pass is focused on that path: get the normal close operation through teardown, prove reopen, and then repeat the cycle enough times to make sure we have not merely gotten lucky once.
    Until that works, I am not calling the Terminal lifecycle finished.
    The Native NuDOS Adapter Still Has Work Left
    There is another distinction worth keeping clear.
    NuDOS itself now has substantial portable implementation behind it.
    That does not mean the complete native Ceylon NuDOS environment is finished.
    The final native adapter is still not qualified, and the full target session has not yet been run end-to-end.
    That distinction matters because I do not want to repeat one of the project's recurring bad habits: proving ninety percent of a path and then mentally promoting it to one hundred.
    The command engine can be good.
    The Terminal can be good.
    The session transport can be good.
    The clipboard can be good.
    And we can still be missing the one piece that makes them behave like one...
  • Project Ceylon Development Log — October 10, 2026: Asteroids Finally Started Acting Like an Application
    Mike • 10/11/2026 at 06:54 • 0 comments
    Mike · October 10, 2026
    Tags: Project Ceylon, Operating Systems, NuGUI, Nu-Iris, Asteroids, NuDOS, Rust, Application Runtime, Testing
    There are certain milestones in an operating-system project that look completely unimpressive if you describe them badly.
    Today we got one of them.
    Asteroids launched.
    It accepted real keyboard input.
    The ship actually responded to it.
    It kept receiving timer events and drawing frames.
    Escape caused the application to exit.
    Its resources were cleaned up.
    The desktop came back.
    Then we launched it again.
    That last part may be the most important.
    A demo that runs once is a demo.
    An application that can be launched, interacted with, closed, cleaned up, and launched again is starting to look like part of an operating system.
    Today Ceylon got considerably closer to that second category.
    The Timer Was Lying in Wait
    We started the day chasing a timer race.
    Asteroids had already reached the point where it could get far enough into the application path to expose problems that simpler tests were not finding.
    One of those was in the timing path.
    The application could register for timer events, but there was a race between registration and the point where the application actually began waiting for them. Under the wrong ordering, the event could arrive at exactly the wrong moment and the application would sit there waiting for something that had, technically, already happened.
    Those are always fun.
    The repair was small in terms of code, but important in terms of behavior. The clock path was corrected, the governed build passed, repeated timer events arrived, and Asteroids made it through another frame and back through the normal NuGUI/Nu-Iris presentation path.
    No timer fault.
    No panic.
    No shortcut around the application architecture.
    That got us past one obstruction.
    Then input found the next one.
    Input Was Connected, But Not Quite Alive
    The semantic-input path had its own problem.
    The application input page was being reset in a way that also erased the ABI identification fields that told the receiving side what the page actually was.
    So the transport existed.
    The application existed.
    The data path existed.
    And we had managed to wipe the sign off the front door.
    That was repaired by restoring the input-page ABI magic and version correctly during reset.
    After that, the real HID path made it all the way through NuGUI focus handling and into the application.
    Not injected test input.
    Not a host-side simulation.
    Real input from the machine.
    The first useful proof was simple: Left and thrust events reached Asteroids.
    That was enough to show the path was connected.
    It was not yet enough to say the game was playable.
    So we kept going.
    Then the Ship Actually Moved
    The next qualification pass exercised the normal game state rather than merely checking whether an input event appeared somewhere.
    Rotation affected the aircraft—well, spacecraft.
    Thrust affected movement.
    The timer continued to advance the simulation.
    Rendering continued.
    Presentation continued.
    The existing Asteroids tests, platform-core tests, and clock tests all remained green.
    At that point, the application was responding to real Ceylon input and advancing through the real runtime path.
    There was one important qualification attached to that result:
    we were running QEMU without a visible display for that particular test.
    So we proved gameplay state and the presentation chain operationally, but we did not pretend that meant a human had stood there and visually verified every rendered frame.
    That distinction has become almost a reflex around here.
    I consider that progress too.
    Closing an Application Turns Out to Be an Operating-System Feature
    Once Asteroids could run, the next question became:
    what happens when the user is finished with it?
    That sounds trivial if you are used to an operating system that already has thirty years of application-lifecycle machinery underneath the close button....
  • Project Ceylon Development Log — October 9, 2026: Asteroids Is Running. Please Don’t Call It a Game Yet.
    Mike • 10/10/2026 at 07:56 • 0 comments
    Today was not a dramatic Ceylon day.
    It was a slow, sleepy, stare-at-the-same-log-for-too-long kind of day.
    Most of it was spent trying to get Asteroids across the line from:
    “there is application code in the machine”
    to:
    “I can actually sit down and play Asteroids.”
    We are not there yet.
    But we're considerably closer than we were yesterday.
    The Good News: It Actually Launches
    The application path made real progress.
    Asteroids can now make it through the normal Ceylon machinery far enough to enter its native application code, get a drawing surface, and push application pixels through NuGUI and Nu-Iris toward the display.
    That's important because this is no longer a fake built-in demo or some special test program living outside the normal application model.
    We're trying to make the game behave like an actual Ceylon application.
    Application exists.
    Desktop discovers it.
    User launches it.
    Application gets an isolated runtime slot.
    Application gets a window/surface.
    Application draws.
    That much is becoming real.
    The Bad News: Blue Is Apparently a Video Game Now
    At one point we had a screenshot that, according to the instrumentation, contained Asteroids output.
    I looked at it.
    It was blue.
    Mostly blue.
    There were a few tiny white points hiding in there if you were feeling charitable.
    Technically, those pixels had traveled through the right machinery.
    Technically, the application had produced output.
    Technically, I suppose this was progress.
    Visually?
    Nope.
    If I showed that screenshot to somebody and said, “Look, Asteroids is running,” they would quite reasonably assume I needed sleep.
    So we tightened the definition of success.
    “Application pixels reached the display” is useful engineering evidence.
    It is not the same thing as:
    “Asteroids is visibly running.”
    And neither of those is the same thing as:
    “Asteroids is playable.”
    Operating-system development apparently requires a surprisingly large vocabulary for saying, “Almost.”
    Then We Had to Make Time Exist
    Once the application could launch and render something, the next problem was animation.
    The host version of the game already has a perfectly good game loop.
    We're not rewriting that.
    The job is to replace the host computer's timing assumptions with Ceylon's own timer/event machinery.
    That sounds simple.
    “Send the game a tick every so often.”
    Sure.
    Except the timer has to belong to the correct application instance, survive the right things, disappear when the application disappears, avoid delivering stale events after a restart, and arrive through the same bounded runtime model as everything else.
    Eventually we did get legitimate timer-driven application updates moving through the Ceylon path.
    Frames started advancing.
    Which means we've progressed from:
    blue rectangle
    to:
    blue rectangle capable of changing over time.
    Look, I'm taking the wins where I can get them.
    Input Is the Next Annoying Little Detail
    Of course, an animated Asteroids game that can't hear the keyboard is basically a screensaver with ambition.
    So the remaining work is centered on the semantic input path.
    The keyboard already exists.
    NuGUI already receives input.
    Asteroids already knows what “left,” “right,” “fire,” and “thrust” mean.
    The missing bit is proving that the normal Ceylon path reliably carries those user actions all the way into the running application instance and that the game responds properly.
    No direct injection.
    No test-only shortcuts.
    No reaching around the desktop and poking the game with a stick.
    The point of this exercise is not merely to get Asteroids working.
    The point is to prove the path that every later interactive Ceylon application will need.
    Which is why a tiny arcade game has somehow become an operating-system integration test.
    I regret nothing.
    Mostly....
  • Project Ceylon Development Log — October 8, 2026: We Fixed the Filesystem. Then We Went App Shopping.
    Mike • 10/09/2026 at 23:22 • 0 comments
    Today Ceylon did something deeply suspicious.
    It saved a file.
    Then it rebooted.
    Then the file was still there.
    I know. Wild stuff.
    For a normal computer, this is not exactly a headline feature. For an operating system we're building from the microkernel upward, though, persistence is one of those wonderfully ordinary things that requires a ridiculous amount of machinery to be correct underneath it.
    And today we got a much better handle on that machinery.
    Storage Finally Behaved Like Storage
    The filesystem repair work moved from "we think we know what's wrong" into an actual qualified fix.
    The repaired path passed the ext4/JBD2 tests, created and read a 6,144-byte file, edited and saved a 9,216-byte file, rebooted the machine, and recovered the data afterward.
    The resulting image was also reproducible. The governed build inputs and payload checks passed, and we got the same ISO again.
    That's the sort of boring result I want more of.
    Create something. Save it. Reboot. It's still there.
    There are entire layers of engineering hiding under those four sentences.
    The application-runtime work also got considerably farther. The core runtime tests reached 48 out of 48, and later filesystem qualification reached 80 out of 80 with the filesystem reaching its Ready state.
    But there's an important line I don't want to blur:
    Ceylon still has not proven the complete normal application-launch path.
    The runtime machinery exists. The filesystem can hold the application. The catalog and drawer concepts exist.
    What still needs proof is the entire normal path from:
    application on disk → discovery → drawer → user selection → launch
    No cheating with a test fixture or direct invocation.
    If I click the thing, the thing should run.
    Apparently that's considered desirable in desktop computing.
    Asteroids Volunteered as Tribute
    We've been looking for a small real application to use as the first proper windowed-app qualification target.
    Asteroids is getting that job.
    The host-side version is in decent shape. Its tests passed, and the repaired demo ran for 1,800 frames.
    What it does not have yet is the complete Ceylon-side entry point, packaging, NuGUI adapter and normal discovery/launch path.
    That's actually useful.
    A tiny game is a much better application-runtime test than a fake "hello window" program because it wants input, drawing, timing and a real event loop.
    And if the application loader is broken, at least eventually we'll be able to demonstrate the failure with an asteroid.
    Then We Went Rummaging Through Somebody Else's Workshop
    A large part of today was application research.
    We spent time looking closely at the open-source ArtCraft family of Rust applications.
    There are twelve projects in the set, covering areas like PDF work, audio, image editing, vector graphics and other creative and productivity tools.
    Rather than immediately forking everything and announcing that Ceylon now has twelve new applications—which would be an excellent way to create twelve new problems—we took the less exciting route.
    We preserved exact source snapshots, pinned the versions, recorded the manifests and hashes, reviewed the dependencies, reviewed the licenses, and started separating the useful application engines from the assumptions those applications make about their current desktop environment.
    In other words:
    Preserve first. Understand second. Port third.
    No ArtCraft application was proven running on Ceylon today.
    That's the research result, not a disappointment.
    The interesting part is that several of them look potentially reusable if we can give them a proper Ceylon application/runtime layer instead of attempting to drag an entire foreign desktop framework into the operating system.
    NuGUI Does Not Need to Become egui
    That led into a useful UI discussion.
    A number of the ArtCraft applications use Rust's egui toolkit.
    NuGUI and egui are not the same kind of thing.
    NuGUI is part of Ceylon's desktop architecture. egui is...
  • Project Ceylon Development Log — October 7, 2026: The Build Reproduced. Then We Started Designing What Runs on It.
    Mike • 10/09/2026 at 02:33 • 0 comments
    Mike · October 7, 2026
    Tags: Project Ceylon, Operating Systems, Reproducible Builds, Storage, Browser, Video, Audio, FFmpeg, VST, Applications
    Yesterday was mostly about figuring out what kind of applications Ceylon eventually needs if this thing is supposed to become somebody's actual computer.
    Today started by making sure we can reliably build the computer underneath them.
    That seems like the correct order.
    It would be slightly embarrassing to spend months designing a browser, video player and music-production environment only to discover that two nominally identical Ceylon builds are actually different machines.
    So a significant part of today's work went back down into the build and qualification machinery.
    And, for once, it gave us a pleasantly boring answer.
    Build it twice. Get the same thing twice.
    That's a milestone I will happily take.
    The Build Finally Had to Prove Itself
    We've been tightening the Ceylon build process for a while now.
    The rule we've settled on is deliberately unforgiving: there is one governed candidate, one expected source baseline, one manifest describing what belongs in the image, and one qualification process.
    If an expected input is missing, that's a failure. If an input is the wrong one, that's a failure. If a payload doesn't match what the manifest says should be there, that's a failure.
    No "well, the ISO still booted."
    No quietly grabbing whatever happens to exist in an old build directory.
    No reconstructing history from shell scrollback three days later.
    Today's canonical image run got through that process cleanly.
    All 7 expected build inputs were accounted for. All 46 expected payload checks passed on the first build.
    Then we built it again.
    All 46 passed again.
    More importantly, the two ISO images were byte-for-byte identical, with the same SHA-256 hash.
    That is considerably more interesting to me than "the build completed successfully."
    A successful build tells you the build system made something.
    A reproducible build tells you it made the thing you intended to make.
    The resulting image also made it through the initial QEMU smoke path: GRUB loaded, the microkernel started, the system environment came up, and the Intel IOMMU configuration was present.
    So the build side of the machine is getting much less mystical.
    Good.
    Mysticism is a terrible dependency manager.
    Runtime Testing Immediately Found Something Else
    Naturally, once the build process stopped being the problem, runtime testing found something else to complain about.
    One test configuration produced what looked like an RNG failure.
    That would have been irritating because the RNG path has already been through quite a bit of qualification.
    It turned out the failure wasn't really about the RNG.
    The wrong QEMU invocation had been used.
    A one-drive configuration had been run where the intended machine expected the fuller storage setup.
    That changes more than "there is one less disk."
    Ceylon's qualification work increasingly treats the complete machine definition as the artifact: devices, ordering, storage layout, firmware, launch arguments, everything.
    So testing the wrong launch configuration and then blaming whichever service screams first is not particularly useful.
    Once that was understood, the storage investigation got more interesting.
    Storage Managed to Make Logging Look Guilty
    One of the problems we found involved filesystem metadata being damaged during a run.
    For a while that looked suspiciously like the storage stack itself had gone off the rails.
    The trail eventually led somewhere stranger.
    Diagnostic logging activity had managed to overwrite part of the ext4 image metadata.
    That is the sort of sentence that makes perfect sense after you've spent enough time building an operating system and absolutely no sense before.
    The other storage issue was architectural rather than corruptive: one composition path only represented a single block device even though the QEMU machine had a...
View all 58 project logs
  • 1
    Installation: N/A
    There is currently no public build or install procedure. Source and
    build tooling exist only on the development machine — nothing here
    can be reproduced by anyone outside it yet.
View all instructions
