## How Dynamic Zero Works
Dynamic Zero uses the pneumatic state retained from the preceding half-cycle as part of the interaction that creates the new acoustic state.
The previous pneumatic state does not disappear when the next half-cycle begins. Pressure distribution and air-mass momentum remain physically present inside the DZ network and interact with the new driver input.
### MOPA Analogy
A useful conceptual analogy is a Master Oscillator Power Amplifier (MOPA). DZ is not an acoustic implementation of an optical MOPA; the analogy refers only to combining retained energy from a preceding state with new input energy.
In the ideal periodic T/2 case:
p(t-T/2) = -p(t)
After pneumatic inversion:
p(t) + [-p(t-T/2)] = 2p(t)
The ideal pressure ratio is therefore 2:1, corresponding to approximately +6 dB. This theoretical value cannot be achieved in a real DZ system due to unavoidable losses.
The important point is simple:
**The new input does not start from zero. It interacts with energy retained from the preceding state.**
DZ is not tuned by resonance. Internal resonances inevitably exist, but they are treated as parasitic conditions to be minimized rather than as the operating mechanism.
Mindaugas Mickus
nobcha
John Anderson
Jakub Laník
