Mp3 player that only plays on real tape decks
I made an mp3 player that only plays on real tape decks. It reads the takeup wheel motion to start and stop playing with a small encoder
I made this mp3 player that only plays inside a real cassette tape player. It's powered by an Xiao ESP32-S3. I chose the Xiao because it has a charger built-in and it's surface-mountable. Music is stored on a standard microsd card. For audio output it uses a PCM5102a. The PCB is really simple because most of the complexity is offloaded to the xiao. In fact, there are ONLY 10k resistors on the whole board! The most complicated part was reading the take up wheel rotation, and that was done with a very small Alps encoder. That specific encoder is the EC05E1220401 and it's only 2mm tall which allowed me to fit in the 6mm of headroom in a cassette. It's wired just like any other 3 pin encoder. Here's the youtube video of the build: https://youtu.be/otXrFBq0HWQ This project was sponsored by NextPCB Get your first PCB order for $0.1 via NextPCB: https://www.nextpcb.com/?code=JonathanRowny Build PCBA in days with fully automated assembly: https://www.nextpcb.com/rev0-pcb
Ken Yap wrote 10/05/2026 at 02:07 • point
C-32GB, hahaha. 😉👍
uk4dshouse wrote 10/04/2026 at 22:17 • point
Nice. I have a similar project too.
https://hackaday.io/project/206816-mp3-player-cassette
Dave Doerr wrote 09/29/2026 at 14:48 • point
Brilliantly absurd concept. I vote for this project to win!
Mike wrote 09/26/2026 at 11:13 • point
This is a really clever idea!
David wrote 09/23/2026 at 18:06 • point
Good idea!  I love the project, as I am the only one in my group of nerds who actually has a working dual cassette unit remaining in my home stereo setup.  It's mostly Kenwood equipment here now, although I was pretty serious about cassettes back in the 80's/90's and owned a Nakamichi deck for recording to mostly TDK MAXG media.  Today most of my recording involves one of my TASCAM units to digital format.  But the nostalgia for the "old days" beckons.  Thanks for your hard work on this!
David wrote 09/23/2026 at 16:28 • point
The only thing I see wrong about this is the lack of magnetic tape to break and/or get destroyed by the dirty tape capstan roller.  And for accurate experience reproduction, well where's the fun in that?  So, well done on the design!
I _AM_ curious about the audio quality using the magnetic head to feed analog signal to another magnetic head.  I'm guessing that there must be some loss in sound quality simply due to conversion back from digital to analog as well.  But since most cassette audio quality loss always seemed to be affected by head alignment as well, I have to assume that may also play into the quality here?
Jonathan Rowny wrote 09/23/2026 at 17:19 • point
The tape head was stolen from an 3.5mm to tape deck adapter, so if you've ever used one of those back in the day, it sounds basically the same as far as I can tell. I don't have access to a really good tape deck, so it's hard to tell, but it does sound like there's very little noise or anything to me.
Been toying around with adding a software digital EQ to it.
