MD Performance CAD SOLO is an engineering software platform developed specifically for PCB reverse engineering and digital reconstruction. MD Performance CAD SOLO allows engineers to reconstruct printed circuit boards from high-resolution images, synchronize PCB layers, trace copper connections, place vias and components, and create an accurate digital representation of the original board. The software uses calibrated PCB images as a foundation for reconstruction, allowing engineers to maintain accurate scale and alignment between different board layers.The system provides tools for reconstructing copper traces, vias, components, board outlines, and electrical connections while preserving the geometry of the original PCB. The project also includes a structured component library, layer management, project history, and tools for analyzing electrical connectivity between reconstructed PCB elements.The current SOLO version is designed for individual engineers, while the architecture is being developed with future expansion toward collaborative engineering workflows and advanced PCB analysis tools. The long-term goal of MD Performance CAD is to create a complete engineering environment for PCB reverse engineering, from physical board analysis to accurate digital reconstruction and documentation. A key objective is to reduce the amount of manual work required during PCB reconstruction while giving engineers precise control over every reconstructed element and electrical connection.
