It was relatively easy to create models that could classify a few sounds. I used Edge Impulse to train them. At that time the most difficult task was finding training data and cutting it into the correct window size. My favorite sounds to teach and to show the proof of concept were "Cough", "Clap", and "Whistle", sounds that I could easily make to test my models. My wife learned quickly that if there was clapping, or coughing, or whistling in the house, I was testing my project.
Anyways, my hardware setup for the first proof of concept was an ESP32-S3 dev board and 3x INMP441 modules, and at that time I also had some LD2450 and LD2451 radar modules that I was testing.
Here you can see my "sentry tower" setup. A slice of pool noodle with holes for the mics and a channel for the wiring, covered by a sock.
At that time I also came across Google's YAMNet and TFLite. YAMNet already knew 521 sounds, far more than I could ever collect training data for, and TFLite Micro was the way to run a model like that on a microcontroller - except it didn't fit on my microcontroller. So from then on the task was fitting it onto an ESP32-S3.
ststephen510
