In my job, RC means release candidate. This means that after my proof of concept, I thought this project was cool and that maybe someday I could convince others that this is a pretty useful sensor to have. My wife and I were staying with my parents and parents-in-law during a period of parental leave (thank you, California), and that is when I was able to learn so much about PCB design. I used KiCad (also thank you, KiCad, for providing this awesome tool for free) and redesigned my board three times, because by the end of each redesign I had learned so much that I thought it would be best to just design the PCB one more time. I learned about these amazing datasheets for each component, about PCB manufacturers, about trace widths for data and power lines. And probably a few hundred other lessons.
In this prototype, I designed a LoRa breakout board, a mic breakout board, a controller board, and an enclosure. The main issues on this design were:
- Battery charging not working
- Singing caps
- Hot inductor
- A missing pull-up on EN, which kept the board from working. I had to bridge EN to +3V3 on each board to make it work.
ststephen510
