RC2, my second release candidate :). So much better than RC1. Charging and charge status now work beautifully. I'm using a Texas Instruments BQ24295RGER, a TLV62569DBVR, and an ADC [for battery voltage]. No singing caps. I switched the LoRa module from NiceRF to an EBYTE module, and the Quectel module from L76K to LC76GAB. The antenna matches the EBYTE modular approval for FCC. All the changes are mainly driven by FCC and CE RED certification.
The issues with RC2:
- My Rainsun GPS1003 is just not seeing any satellites. I'm so convinced it must be an issue with the new LC76GAB that I message Quectel. I receive a firmware update for the GNSS module, but still nothing. I hold a big ceramic antenna to the module, and then and there I receive an abundance of satellites. I decide that the next prototype version needs a ceramic antenna.
- Do you see the three tiny holes on the top of the enclosure? These are to press the reset, boot, and user button with a toothpick :). Never liked that solution, so the next prototype has this solved.
ststephen510
