ESPager
Bringing pagers back to life using an ESP32 C3 and the Pager's Original Hardware, then sending pages through a web interface or using a pbx.
The ESPager project by Hardcore Corey Harding transforms a vintage Motorola Advisor pager into a Wi-Fi-enabled device. Instead of a traditional radio network, the project replaces the internal radio module with an ESP32-C3 microcontroller. The ESP32 "bit bangs" an encoded signal that mimics a real pager transmission, tricking the original processor into believing it received an authentic page. This allows messages to be sent via a web API, triggering the original alerts and display without a paging service. Pushing the concept further, a custom PBX extension on a FreePBX 17 / Asterisk server can be dialed to prompt a caller for a callback number. This number is pushed through the web API, and the pager alerts exactly as it would from a real service. The pager's main hardware isn't emulated, it's the real thing, just like it was back in the day. The soul remains intact. You're not building a tribute, but a bridge from 2026 to the 1990's out of a few lines of code and an ESP32.
Demo using Asterisk PBX and web API:
 (My son demonstrating ESPager using our payphone we restored)
Demo using the web interface:
 (No PBX needed)
What sets this project apart from others:
 * Reuses the real pagers original hardware
 * Works with POCSAG or GSC (Golay Sequential Code) pagers
   ** (The first project I have seen that is actually compatible with the GSC Pagers)
 * Minimal parts list/modifications
 * Easy to use web interface
 * Integrates easily with asterisk PBX software
 * STL files to 3D print your own programming adapter for Motorola Advisor
 * Hack the Planet retro inspired theme makes it feel period correct
 * XIAO ESP32 C3 has a built in battery charging circuit and you can trim the bottom of the pager to expose the USB C port.
JPEG Image - 350.64 kB - 10/09/2026 at 11:47
Preview
Portable Network Graphics (PNG) - 438.21 kB - 10/04/2026 at 03:26
Preview
Portable Network Graphics (PNG) - 277.19 kB - 10/04/2026 at 03:26
Preview
Portable Network Graphics (PNG) - 264.46 kB - 10/04/2026 at 03:26
Preview
Portable Network Graphics (PNG) - 197.66 kB - 10/04/2026 at 03:26
Preview
View all 42 files
  • 1 × 1st Generation Motorola Advisor (or Pager that supports POCSAG or GSC)
  • 1 × XIAO ESP32 C3 with built in battery charging (or Generic ESP32-C3 SuperMini)
  • 1 × 10440 Button-Top 3.7v Vapcell F4 450mAh (or Generic USB C Rechargeable 3.7v 10440 750mWh 200mAh, maybe a 601230?)
  • 1 × Tiny Out 1A LDO 1.8V (or mini DC-DC Buck Converter 1.5v output voltage with 2.5v-6.0v input voltage)
  • 1 × 3.7v 1S 2.5A li-ion BMS Protection Module with Overdischarge protection (Round type that goes on end of 18650 is smallest I foun
View all 10 components
  • 1
    Detailed instructions available on the GitHub Repo.
    https://github.com/exploitagency/ESPager
    The repo includes:
    * Source code for ESP32 C3
    * Programming instructions
    * Pager disassembly
    * Hardware modifications
    * Brief overview of the web API
    * Dial plan and FreePBX 17 / Asterisk instructions
View all instructions
