Modular Platform for AEM Water Electrolysis
Research cells in 1, 5 and 25 cm² active areas for catalyst, electrode and membrane testing in AEM water electrolysis.
Public Chat
0 followers
We are developing a modular research cell platform to study anion exchange membrane (AEM) water electrolysis at 1, 5 and 25 cm² active areas. Our aim is to understand how electrode and membrane performance changes as testing moves from small samples to larger cells. The work involves machined flow fields, cell sealing and compression, electrolyte circulation, electrical connections and operating-data collection. This project documents the hardware, experimental setup and lessons from testing. We will share photographs, operating videos and development logs, including challenges encountered along the way. We welcome technical discussion on flow distribution, bubble removal, thermal management and reliable electrolysis measurements.
Green hydrogen can be produced by splitting water into hydrogen and oxygen using renewable electricity. Anion exchange membrane (AEM) water electrolysis is one approach being explored to support this transition.
Our work focuses on the research needed to move from individual catalysts, electrodes and membranes to an operating electrolysis cell. Performance at a small active area does not automatically translate to a larger cell: flow distribution, gas removal, electrical contact, temperature and compression all influence operation.
We developed a modular research cell family with 1, 5 and 25 cm² active areas to investigate these questions and support the development of AEM electrolysis technology for green hydrogen production.
The cells use machined SS316L plates with flow channels, replaceable sealing components and bolted assembly. This allows electrodes and membranes to be changed between experiments and components to be inspected after testing.
The three sizes support different stages of our work:
  • 1 cm²: initial material screening.
  • 5 cm²: electrode and membrane evaluation.
  • 25 cm²: larger-area testing and investigation of cell operating behaviour.
Experimental setup
Our laboratory setup combines the research cell, electrolyte reservoirs, circulation hardware and a programmable DC power supply. We also developed PC-based data acquisition to record current and voltage over time.
Timestamped measurements help us relate changes in cell behaviour to adjustments in operating conditions and identify interruptions or unexpected events during a run.
What we are investigating
We are interested in how flow-field geometry, electrolyte circulation, gas bubbles, temperature and assembly conditions influence cell performance. Moving between active areas helps us investigate behaviour that may not be apparent in small-sample experiments.
  • Watch the 25 cm² operating demonstration
    Ajay Saini • 10/05/2026 at 11:19 • 0 comments
    This video introduces our laboratory setup for testing the 25 cm² AEM research cell.
    The cell is operating at 25 A, corresponding to a current density of 1 A/cm² across its 25 cm² active area.
    The setup includes electrolyte reservoirs, circulation hardware, tubing and electrical connections to the DC power supply. The demonstration provides a view of the assembled system during operation.
    During testing, we are examining electrolyte circulation, gas removal and temperature behaviour alongside current and voltage measurements. These factors matter when interpreting results and comparing different electrodes or membranes.
    Future logs will describe the measurement approach and individual experiments in more detail.
    Operating video: CLIMAFOUR Labs | 25 cm² AEM Electrolyzer Cell Operating at 25 A - YouTube
    How do you monitor temperature and manage gas bubbles in your electrolysis test setup? We would welcome suggestions from others working with similar cells.
View project log
