I am working on an IoT-based power monitoring project using an ESP32 microcontroller to monitor electrical consumption and control selected electrical loads automatically. The main idea behind this project is to develop a smart system that provides real-time information about electricity usage while reducing the need for manual monitoring. By combining sensors, relay modules, and IoT functionality, I want to create a practical solution that can be used in homes, small offices, workshops, and other environments where keeping track of power consumption is important.
One of the main features of this project is continuous measurement of electrical parameters, including voltage and current. The ESP32 will collect readings from suitable voltage and current sensors and use this information to calculate real-time power consumption. These measurements will help users understand how much electricity connected appliances are consuming at a particular moment. The collected readings could also be displayed in a simple visual dashboard, much like how Alight Motion uses visual elements to make editing projects easier to understand, helping users interpret electricity consumption trends more clearly. I also want the system to track accumulated energy usage over time so that it becomes easier to analyze consumption patterns and identify appliances or periods that contribute to higher electricity usage.
Another important part of the project is automatic load control through relay modules. Instead of simply displaying electrical measurements, the system will be able to switch selected loads on or off according to predefined conditions. For example, if power consumption exceeds a configured threshold, the ESP32 can trigger a relay to disconnect a selected load, provided the load and switching arrangement are designed for that purpose. These conditions will be configurable so that the system can be adapted to different applications without requiring major changes to the overall design.
I also plan to develop a simple web interface that allows users to view power monitoring information conveniently. The interface will display important readings such as voltage, current, instantaneous power, and accumulated energy consumption. This will make it easier to check the system's status without directly interacting with the hardware. Depending on the final implementation, the ESP32 can provide access to the interface through a local network, allowing users to monitor the connected system from a browser on a computer or smartphone.
Historical data storage is another key feature I want to include. Rather than showing only the current measurements, the system will store previous readings so that consumption can be reviewed over time. This information could help users compare usage at different times, understand recurring increases in power demand, and make more informed decisions about electricity consumption. I also intend to implement alerts that notify users when consumption exceeds a defined limit, making it easier to identify unexpected increases and respond before they become a larger concern.
Overall, my goal is to build a compact, flexible, and affordable smart power monitoring system that combines measurement, data logging, automatic switching, and remote monitoring in one project. The ESP32 provides a suitable foundation for integrating these functions because it supports wireless connectivity and can communicate with different sensors and control modules. As development progresses, I plan to focus on measurement accuracy, reliable data collection, configurable automation rules, and a user-friendly interface. Since the project involves electrical monitoring and relay-controlled loads, I will also account for appropriate isolation, correctly rated components, enclosure protection, and safe wiring practices, particularly when working with mains electricity.
