Digital DM Screen
Electronics project with a 3D printing component
kiaKia
I travel in order to DM for a homebrew D&D campaign I run. This means I can't have a permanent setup at home and I use a laptop for all my notes and etc. Every time I arrive and I setup I have to remember to setup my bluetooth speaker, my laptop, put out the world map, and hang the current month calendar off the back of the DM screen. My DM screen has stuff printed on it but I never see any of it because my laptop is always blocking it. I also need to set down my notebook and my dice tray and there's just no space with my laptop in the way. I saw someone created a DIY DM screen which had a player facing screen on one side for you to display images or whatever to your players. But I want something that replaces both that AND my laptop. I only want to have to carry one thing.
The ideal list of features this screen would have:
  • Player facing screen for showing monsters, maps, calendar, etc
  • DM facing screen that supports touch
  • A computer brain that can replace a laptop for DM purposes
    • Able to connect to the internet via wifi
    • Able to output different video to 2 different screens
    • Able to connect at least 3 bluetooth devices:
      • Mouse
      • Keyboard
      • Speakers
  • Built in speakers that face the players, and maybe optionally the DM, so that a bluetooth speaker isn't necessary
  • Ability to plug in 1 USB device (such as a streamdeck)
  • Ability to run off a battery like a laptop does (but able to still run while plugged in incase the battery doesn't last long enough)
    I realize that some of these are lofty goals so I'm aiming for a v1 which does not have built in speakers, and does not have a battery (must be plugged in to a wall to work)
    For the physical shape of the project, I want it to fit these requirements (both personal/generic):
    • Fit into my DM bag (or, if not possible, a generic laptop bag). The bag is 40 cm wide at best, around 25 cm tall at best, and the space for the screen could be about no more than 8cm deep
    • Be lightweight enough to not feel like I'm lugging around a ton of bricks (less than a laptop? equal to a laptop?)
    • Be taller than an average off the shelf DM screen (<20cm)
    • Be no wider than an average DM screen, maybe a bit smaller, but wider than some custom DM screens I've seen (so between 90cm and 108cm)
    • Be able to be printed on my A2L 3D printer -- so no individual piece is larger than 33cm x 32cm x 32.5 cm
    • Be made of 3 pieces, one large center piece, and 2 side wings that fold up and meet in the middle of the center piece (so the middle = the width of both wings)
    After sourcing a few components, and playing around with dimensions, I landed on the following dimensions:
    • side panel = 25cm x 25cm (thickness undetermined)
    • center panel = 50cm x 25cm x 1.5cm
      • in order to fit on the print bed, it will have to be split in half down the middle and print as 2 separate piece
    Another requirement I landed on while playing around with the enclosure is that I want to be able to take it apart easily if anything needs to be tweaked or fixed or maintained or replaced. The best solution I came up with for this, was to split the screen in half along it's thickness. This gives a few other benefits:
    1. Both the DM panel and the player panel can be placed face down on the print bed to get a consistent surface finish
    2. The cavities inside the panel for components don't need supports in order to prevent sagging, because they will only open upwards with no flat portion above them
    And lastly, the most recent requirement I added to the list is that because I am splitting the panel down the middle, and it has 2 screens inside it, it will need a lot of strength and support, so I will need to print a solid piece inside that is no more than 33cm x 32cm so that it can be printed as one for strength.
    • I am screwed! Not literally...
      Kia • 10/27/2026 at 00:04 • 0 comments
      I couldn't resist the need for a pun. So today's post is all about screws if you didn't guess. After my last post I realized I really needed to buy screws so I could test it out, because apparently the only ones I had were M3 screws. I did briefly debate changing my whole design but then remembered the M2 requirement was... imposed on me by the laptop screens so no dice. However, spoiler alert, I did have to change my whole design... kind of.
      Thus began my week long journey of "what the heck screws do I buy". If you look at my design files, they required 16 roughly 6-8mm long M2 screws.
      I spent a decent amount of time trying to find 6mm long M2 screws, that came in a pack of different sizes because I wanted more future utility out of the screws, only to find out that 6mm is not a standard size. Not that 6mm would be impossible to find, but it just didn't come in kits that had different sizes. M2 really only came in 4mm or 8mm. The other caveat I threw at myself, is I ALSO wanted the kit to come with the heat set threads. This made it even more difficult to find.
      At one point I resigned myself that I wasn't going to be able to get a kit that had everything I wanted so I was just going to buy the screws on their own, still buy a kit, and also buy heat set inserts. So I went on a journey to try find this. However, I ran into some more struggles.
      If you remember back to my design, the tabs are sitting pretty close to flush to the front of the dm screen. Meaning there is very little space for the head of the screw. After considering button head screws and countersunk screws and various other head styles, I realized, no matter what I did, these screws were going to stick up from the panel a decent amount. Oh and don't forget, even if I could find something that maybe might have worked, which I did at one point on digikey, it was like $10 for 10 screws. Which is insane given I need 16 of them and it still wouldn't be what I wanted it to be.
      After almost a week of searching I finally decided what needed to change was my design, I just had to give up on the M2 screws being the only screws and holding everything together. And boy was this freeing.... but yet again still came with it's own challenges.
      So my new plan was design this to use laptop screws essentially, so they would be short M2 style screws like what you'd get in laptops and stop trying to fight that design. Which means I needed new screws to hold the frame pieces together and also to hold the frame pieces to the support insert. I thought I had the perfect plan.
      There are some spaces to the right of the tabs on the bottom (pictured above) and some space on either side of the tabs on the top (pictured earlier), I can just put the new screws in those spaces and that will hold the frame pieces to the insert. I drew up some places of where I thought the screw holes would go on my test prints so I could see what it would mean.
      And you may not be able to tell, just like I didn't initially, but the dark dot in the top left lines up with the support insert, the dark hole pictured in the bottom left. But the dark hole in the top right.... doesn't have a partner hole. Instead it touches directly to the other frame, which you can see the back of the other frame with it's hole pictured below.
      Because the edge of the support insert only goes to about where the screws end (pictured below), that meant one set of screws would go through the frame and the support insert, and the other would only go through both frames.
      What I ended up deciding was that this isn't a negative but a positive, I will have one set of screws holding the frame together (2 at the top on one side of the panel, 2 at the bottom on the other side of the panel) and I will have one set of screws hold the frame to the support insert (again, 2 at the top on one side, 2 at the bottom on the other side). This does end up being a little...
    • Testing Fits
      Kia • 10/16/2026 at 22:56 • 0 comments
      Alright so I finally got around to doing a small test print of 1 corner of the screen (all 3 pieces) so I could test if the holes lined up, how the pieces lined up together, and how the print fins worked. And well... it didn't all go as planned.
      Print Fins:
      I either need to dial in the settings or try a different approach because:
      1. There were some unsupported areas that produced a bit of spaghetti.
      2. The holes were unsupported and thus were imperfect at the entry points
      3. The surface that was "floating" and should have been supported by the fins, printed really rough and non ideal, I almost feel like for this project in particular regular supports might have produced a more solid finish.
      In the image below you can see these surfaces, with the holes carved out and a bit of cleanup done on the surfaces themselves but they're still pretty rough.Holes:
      So turns out I thought I had M2 screws and I only have M3 screws so I couldn't fully test these as much as I wanted. But what I was able to determine:
      1. The top holes are aligned perfectly and look great. However because of the printing above, I had to carve out filament from all of the holes.
      2. The bottom holes are misaligned by about 1.5mm (too close to the top, need to scooch down further).
      3. We'll have to wait until I get some M2 screws to test the fit if the holes printed good but they look similarly sized to the actual metal holes so I think they'll likely be fine.
      Overall Alignment:
      Unfortunately I think I chose to print portions that didn't align amazingly so it was a little difficult to test this. Here are the conclusions I was able to come to:
      1. If it wasn't for the poor finish on the floating edges, I think they align to one another great, everything slid in together, the support insert has enough space to slide in easily, but actually has a little bit of friction so it feels snug in a good way.
      2. The channel right below the tab on the bottom portion of the screen makes it difficult at this small scale to tell how the fit in that corner is with the screen, it felt off but I think it was just because of the channel.
      3. The top edge aligned pretty close to flush in all directions which was absolute music to my ears.
      We'll have to see top to bottom and left to right how things fit if they need more wiggle room but I think I'd have to do a full test print to see that and I wasn't at that point yet.
      Given how this test went, I think my next steps are to order some M2 screws, and maybe the heat sunk screws as well to see how those fit in this test print to see if they need to be sized up or down or etc. Once I'm able to test that, I might be willing to print a full test print to see alignment of the full size pieces, alignment with the screens, etc.
      And incase you're wondering, yes, I am putting off testing the actual electronics side of this because I'm still uncertain how I want to go about dealing with the signal, if I trust the random parts I found on amazon to try convert my signal from HDMI to eDP, or what I should do.
      Oh and I'm thinking I might adjust depths of things a bit to get the displays just a little bit further into the screen so that I can put a bezel around the monitor to cover the screws that sits flush with the screen and such but I'm not quite sure and I plan to test more stuff before even thinking about that.
    • It's here!
      Kia • 10/06/2026 at 22:25 • 0 comments
      Can you guess what day it is today? Delivery day! The 2 monitors arrived in the mail today and I'm very excited.
      First thing I realized as soon as I unpackaged it and looked at the tabs for screwing the display down: I want to make the display sit into a bit of a notch. AI had suggested I add tab supports to go behind the tabs, but I think I want it to go all the way around the display so there's a full ledge for the screws to sit on.
      After doing some measurements, I got 1.8mm is the space between the back of the panel and the screw hole tabs. But the tabs on the top and the bottom don't seem to be the same size and it's likely related to the PCB at the bottom of the display, where the 40 pin connector is. The dimensions of the various pieces are as follows:
      • top tab dimensions: 6mm x 12.9mm
      • bottom tab dimensions: 7.2mm x 14.9mm
      • tab depth from back of display: 1.8mm
      • top left tab: 19.5mm from the left of the display
      • top right tab: 19.8mm from the right of the display
      • bottom left tab: 19.8mm from the left of the display
      • bottom right tab: 20.1mm from the right of the display
      The new cutouts I need to add then end up being:
      • bottom left tab area either
        • 7.2mm x 38mm (just the tab depth)
        • 10.8mm x 38mm (full depth of the PCB)
      • bottom right tab area either
        • 7.2mm x 39.6mm (just the tab depth)
        • 10.8mm x 39.6mm (full depth of the PCB)
      • top tab area
        • 6mm x <full width of display>
      Measuring the hole spacing proved to be a lot more difficult and after a lot of varying numbers for the sizes I decided to try trace the outline and measure the outline. I still doubt it was perfect so I'll have to make sure to bake in some tolerance but the hole distances came out to: 7.6mm for the bottom, and 5.5mm for the top. And the holes were all about 2mm from the display. All of these measurements were taken from "center".
      I checked those measurements on my current model and they are either 6mm or 8mm apart, which might be accurate as that's closer to my initial measurements, but it's hard to say. But they were about 3.3mm from the edge of the display at the top, but only about 3mm in real life. I'll have to make sure I do a test print to confirm.
      I took the time as well to make a handful of the tweaks that were suggested when I had AI review my file, to include supports behind the tabs now that I could measure those and etc, can you see those changes below:
      You can see the tab supports near the bottom for each corner, and a full width support near the top. These changes are mirrored on the opposite siders, so the small strip you see at the bottom is the support for the "top" of the panel on the opposite side. One thing I forgot to mention is I plan to mount the player screen upside down in order to have the cables and etc running to the same side of the enclosure, but not be overlapping in any way so the bulk is split between the top and bottom.
      You can see the cable channel now cuts into the support insert as well. I also made a number of tweaks to the screw holes but those are harder to show, just trust me that they're there ;)
    • Catching up on where we are so far
      Kia • 10/06/2026 at 16:55 • 0 comments
      I only just recently thought to start logging how work is going on this project and I'm decently far in so I thought I would just write a catchup post.
      I originally had the idea for this a while back, possibly like 3 years ago? While I was in school. But it didn't seem like a good fit for my school capstone project because it was a fairly narrow purpose. So I shelved it for a long time. I was laid off from my job recently and found I have a lot of free time on my hands, and I've been wanting to get back into working with electronics which I haven't done much of since school because I've been so busy. I picked this project up specifically because I was working on a web app for my DM prep to make my life easier for prepping and also for running the games, and it just gave me the itch to fix more of my problems.
      So about 5 months ago I started working on creating a parts list, and designing the 3D print itself. But I was new to Blender at the time (my choice of 3D design software, in hindsight possibly not the best choice for designing something so... man-made / not organic; but I was learning Blender for a different purpose which was designing 3D prints and I wanted to be able to create cool organic forms to make nerdy versions of various home solutions, so I figured just learning one software was best. Anyways, I digress, I ended up putting a pause on designing it because I had no idea what I was doing and I was getting frustrated.
      Jump to about a month ago, 1 month after I had been laid off, I decided to get back on the horse that is this project. It helped that back in May I had reached out to one of my instructors for advice on the project and he just so happened to get back to me in September. He didn't really give much advice aside from confirming it was ambitious but ambitious may as well be my middle name.
      One thing I should mention is that back in May when I was coming up with a parts list, I was looking for what sort of extremely thin touch screen could I  get that would be larger enough, at least laptop size, that I could embed in a DM screen. And not just one, but 2 of them back to back. The only solution I landed on was replacement laptop screens. These came with a slew of challenges I was yet to realize at the time but I have already started to realize some of those now.
      1. The screens are intended for laptops, so they are super thin, but they expect eDP input. And no simple computer brains (such as a Raspberry Pi) that I could buy, output eDP natively. So I would need to find a way to convert the signal.
      2. Because I only need 2 screens, buying 1 that supports touch, and 1 that does not, is not cost effective, because the price difference isn't that large, so I bought 2 screens that support touch to get a bulk discount.
      3. Unfortunately buying a screen that supports touch but not needing touching doesn't seem to be as simple as "just don't plug in those extra 10 pins" meaning that our problem from #1 becomes even more complicated.
      Converting the signal to eDP is expensive. I looked into buying a card that converts an HDMI signal to eDP and for one that supports touch I found one on amazon but it's reviews are non-existent/garbage, saying that the component got fried and it fried the screens, or that it just didn't work. I also looked into designing my own PCB, something I'm no stranger to, to convert the signal from DSI to eDP, and that would be even more expensive, upwards of $100 or more because of the sensitive traces required for the digital output. I also tried to pivot and look into a native DSI solution that was large enough and that's essentially non-existent.
      So where I've landed for now is that I'll just have to buy the poorly reviewed board, but do some pin testing before I connect the display, and then, buy a cheaper board that doesn't do touch AND a 30pin to 40pin cable, in order to convert the signals for both screens.
      I should...
    View all 4 project logs
