A solder pasting jig holds the stencil in a pocket that keeps it aligned.
A SMD placing jig has apertures that help align ICs when you drop an IC into the aperture.
The FreeCAD designs are parameterized so you can customize them for your PCB and ICs.
I get boards from OSHPark and stencils from OSHStencil.
The boards go in lightweight solar art mobiles.
They are tiny and have only one or two ICs, usually QFN package with say 0.3 mm pins.
I paste and place by hand, using a vacuum pen.
The jigs are not a panacea.
You might find the jigs helpful.
