Resurrecting a 1980s AT&T UNIX System
Restoring an AT&T 3B2/300 and giving it another chance at life in the modern world.
Restoring a 1980s AT&T 3B2/300: hardware repair, disk preservation, UNIX System V recovery, and new software on original hardware.
The AT&T 3B2 was designed to be a native UNIX computer built in around the early 1980's. Unlike the better known 3B1, the 3B2 and other members of the 3B family are designed around Western Electric's own WE32xxx processor architecture which is considered the first 32 bit microprocessor.
Today, surviving 3B's are scarce, with many parts and software being unobtanium. What is available is limited mostly to scans of AT&T's manuals and usenet threads.
This project documents my effort to preserve, repair, understand, and actually use an AT&T 3B2/300.
My goal is to bring this machine back to life, preserve the historic data on it's hard drives, and get it back into action hosting my own BBS. I also plan to provide my own contributions towards the 3B2 community with creating my own schematics for the motherboard and designing modern add on cards that can provide additional functionality to the system to make it a little more useful in the modern world.
The system has presented a long list of problems in both hardware and software.
These have included shorted tantulum capacitors, power supply faults, serial issues and unreliable communications, expansion card hardware issues, hard drive failures, scarce documentation and software, and challenges of porting comparatively modern software on an ancient UNIX machine.
One major goal is preservation. This machine has lived a long life with file dates spanning from 1984 all the way into the early 2000s. I have so far been able to back up one of the three 72mb hard drives it came with and there are ongoing efforts to repair the other two. I wish to preserve and compile the data to tell the story of this machine and the life it lived.
At the same time, I have been trying to push the restored machine past it's original use case. I have since been working on porting software to the 3B2, including compiling more modern shells, compilers, and even games on the system.
Other parts of this project include investigating the 3B2 feature-card architecture, with plans to document and modify my existing cards, as well as designing new cards to add features such as high speed serial communications and removable media.
The restoration is still ongoing. Some problems have been solved, others have exposed entirely new ones, and several pieces of hardware are still being investigated.
That is part of the reason I am documenting the project: there is surprisingly little practical information available today about repairing and operating a real 3B2. I hope the measurements, failures, fixes, software discoveries, disk images, and documentation collected here will also be useful to the next person who tries to keep one of these machines alive.
Here are the specs of my working 3B2/300:
An upgraded WE32100 over the original WE32000 running at 8MHz
3Mb of RAM
72Mb CDC Wren II drive
A Gotek floppy drive emulator
Running System V UNIX Release 3.2
1 PORTS card (upgraded to EPORTS)
1 CTC tape drive card and a corresponding standalone floppy tape drive (currently not working but repairs are in progress)
Additional parts I own:
A second complete 3B2/300 with a WE32100 at 8MHz (currently non-working due to motherboard damage)
4 more PORTS cards (including the one that caught fire)
1 more EPORTS cards
2 more CDC Wren drives (32 and 72Mb, both not working, repairs in progress)
Another CTC tape card and floppy tape drive (also non-working)
An XM expansion chassis containing the other 72Mb hard drive and second tape drive
3 TRW branded power supplies and 1 XM expansion chassis power supply. (Two of the 3 psus are not working and are damaged. The third power supply and expansion power supply are untested)
  • 3B2 Remote Start
    Ashton Vallejo • 10/15/2026 at 16:00 • 0 comments
    After losing functionality of the soft power features when I replaced the PSU for an ATX one, I decided to implement my own. I wanted to make it capable of being started and stopped remotely, with me only having to log into the console and give power commands to the system. I chose to leverage the onboard ATMega32U4 of my lattepanda delta 3 that has been handling the serial communications for me. With a cheap relay board from amazon, I was all set up to start making the power control system.
    Using the vague schematics from AT&T's maintenance reference, and some testing, I was able to figure out how the power and reset system worked.
    The reset circuitry is pretty simple. Grounding pin1 on the power connector causes the 3B2 to reset. The power on circuitry is a little more complex. When pressing the power switch, the power supply switches on, but only as long as the switch is pressed. After it comes on initially, the 3B2 drives pin 7 high which tells the power supply to stay on. Grounding pin 6 will tell the 3B2 to run init 0, which is to power down the system. What is strange is that pin 7's "high" is only 2V, not a normal TTL 5V high. This added a little bit more complexity as the atmega must read pin 7 using it's ADC and compare it to a 1V threshold. If it is above, keep the PSU on. If it is below 1V, kill the PSU. Its a shame that they couldn't reverse pin 7 to drop low to keep the psu on, since then I can just wire the ATX #PS_ON signal directly to pin 7 to handle power control. Oh well.
    The wiring is a bit of a mess, but it gets the job done. Also, I found an array of server fans and slapped it on top to give the 3b2 a little bit of active cooling.
    I added a few different commands to the program, soft and hard shutdowns, cold and warm resets, and then a status command to show some diagnostic data.
  • EPORTS, and Making the 3B2 a Little Bit Cooler
    Ashton Vallejo • 10/15/2026 at 15:37 • 0 comments
    Its been a big week for the 3B2! A kind fellow on the VCFed forums had donated me two spare EPORTS cards he had. That means I can now run serial at 38400 baud, with hardware flow! Before this, the original PORTS card could really only handle 19200 baud and even with that, heavy transfers would quickly fill the buffer and cause data to be dropped.
    The look of these cards compared to the original PORTS cards is really impressive to me. While the original PORTS cards use mostly discrete logic and a dedicated serial controller, the EPORTS are convered head to toe in ASICs. VLSI, ALTERA, even some in-house AT&T chips are on here. Also another interesting note: all of the older feature cards have a socketed 80186 cpu on them with a metal heat-spreader on top. These guys have a soldered on 80186 without any form of heat-sinking. Strange!
    Here's an image of a PORTS card for reference:
    Getting these cards set up on SVR3.2 was a relatively straightforward process. Add the floppy image to my gotek drive, boot UNIX, and run sysadm to install the software package. The system then tells you to reboot the computer, which I did. I made a big mistake in how I rebooted it though. I wanted to first run a set of diagnostics using the DGMON program that UNIX comes with, since I wanted to make sure the EPORTS card was working before I started playing around with it. In order to run DGMON, you first have to boot the machine into firmware mode, which is basically the 3B2's bios menu. After, you tell the prompt which file you want to boot and which device to boot it off of. I was able to boot DGMON and run the diagnostics just fine, but the big mistake is how I then booted UNIX. Under a normal boot, if the system configuration changes, UNIX will run /etc/system. This program rebuilds the UNIX kernel based off of the EDT or equipped device table. It configures what drivers it needs to load and adds them to the /unix boot file. My mistake, was running /unix directly from firmware mode. This completely bypasses the kernel rebuild and instead boots the old kernel. This meant that while the 3B2 could detect the EPORTS card and generate the respective /dev/tty* interfaces, it could not actually access them. I was able to fix this by booting /etc/system from firmware mode on a second boot. As of right now, the EPORTS cards work in some capacity-- they are able to communicate with my laptop fine, but rts/cts is having some issues. I have to diagnose whether it is my adapter wiring, serial cable, or the rj45 port that is causing the issue.
    An additional update: I've taken a small effort into increasing the lifespan of the machine. I purchased a cheap heat sink kit that was meant for a raspberry pi and put heat sinks on most of the bipolar chips since they get hot enough to hurt to touch. I'm sure it really wont do much in protecting the machine, as its been running fine being as hot as it was for the near 20 years it operated before I got it, but at least it gives me a little piece of mind. I especially wanted to preserve the multiple PLA's that were on board, as if one of those fails it most likely will be a death sentence for this machine.
  • Railroads, UPenn, and a Well-Loved UNIX Machine
    Ashton Vallejo • 10/12/2026 at 16:23 • 0 comments
    One of my favorite parts of working with and restoring old computers is learning their story. Old computers are often archaeology sites containing clues about how they were used and where they came from. From the 43MB backup that I took of the hard drive, I was able to recover a significant amount of data that I pieced together to tell the story of this beautiful machine as best as I can.
    Preface
    There was a significant amount of personal data on this drive. Emails, addresses, working documents, and other sensitive information was recovered. I will not be publishing any sensitive material to protect the identities of the owners and their families.
    Names of private individuals, email addresses, phone numbers, personal mail, account information, and similar identifying information have been omitted from this project.
    A Railroad Hiding in the Filesystem
    As far as I can tell, this 3B2 machine started its main service in the railroad business. According to recovered information and some speculation, this machine was originally owned by Anthracite Railway, which is a now-defunct short line railroad in Pennsylvania. There is a significant amount of data to explain exactly what this machine was used for inside of ATRW. There was information regarding railcar movement records, car-hire accounting, billing, switching settlements, invoices, customer and railroad reporting, and equipment records. There are actually scripts that are for generating switching-settlement reports for operations around Pottstown, Kutztown, and Emmaus. Data regarding Octoraro Railway also appears frequently in data, which makes sense as Octoraro was a sister railway to ATRW.
    Running a Railroad, One Shell Script at a Time
    One of the more interesting programs I found on my 3B2 is 20/20, a spreadsheet software from Access Technology. A large amount of railroad work seems to have been built around a mixture of UNIX shell scripts, databases of records, and spreadsheets and reports. A user could select the billing operation they needed, process the car records, generate a report, and print it out. There are even scripts that modify themselves or their working templates from month to month, changing date ranges and regenerating monthly reports. I have reason to believe a lot of this software was written in-house, as one of the owners of this machine worked for AT&T and had experience writing C for them, as well as managing a fleet of 3B2s.
    When the Office Machine Became Something Else
    After several long, fruitful years of office work, this machine started its life as a personal computer. Around the 1990s, the work on this computer had shifted. Now the system is littered with UUCP transfers, including some logs troubleshooting UUCP file-transfer issues. This specific machine's UUCP handle was atrwrail, showing that the owner of this machine had an attachment to the ATRW company. I have reason to believe he was president of ATRW.
    Railroad Knowledge Ended Up in the Courtroom
    Another user on this 3B2 tells another story of use. There appears to be a large amount of data regarding expert-witness and technical consulting work centered on railroads and other transportation. It contains draft reports, case summaries, qualification material, invoices, correspondence, more 20/20 worksheets, case-status files, and documents prepared for attorneys. It seems after this machine had left ATRW it continued its railroad work, with its owner now using their railroad expertise in a legal setting. The surviving qualification material describes expertise in areas including railroad operations, transportation economics, accounting and cost analysis, rail safety, track and right-of-way matters, rolling stock, signaling, tariffs, and vehicle performance. Organizations appearing in the surviving material include names such as Amtrak, SEPTA, Metro-North, Conrail, CSX, the Long Island Rail Road, and WMATA.
    When Registering for Classes Meant Making...
  • UNIX Troubles
    Ashton Vallejo • 10/12/2026 at 14:35 • 0 comments
    Once I was able to fix the serial issues and get the computer back into a fully functional state, it was time to work on the software side of things. There were many things I needed to get in order. I wanted to use it as a developer workstation, writing C for this ancient system. The very first thing I needed to do was get a new shell on there. As much as I love the bourne shell for the history aspect, you really end up taking for granted just how spoiled we are with modern bash and other shells. I had originally wanted to get zsh working on the 3b2 as there is a version of it with WE32K support, however since svr3.2 is pre-POSIX, it was a real struggle to get it to compile properly. Lots of missing headers, configuration errors, and the god-awful AT&T supplied compiler and its ridiculously small memory window. I was able to get a binary for gcc 2.3.3 but even that made life difficult, albeit much easier than before. In the end I temporarily gave up on zsh in favor of tcsh, which was more period-accurate and much easier to compile. Firstly I had to address another issue I discovered-- I had a way out of date copy of the C compiler and my system headers. So I ended up having to fix those too but using the floppy drive to install the 12 different software packages I needed. After that though, compiling tcsh was a breeze and once it was installed, it was like shell heaven. The original bourne shell has no tab autocomplete, no command history, has buffer issues when too many characters are passed at once, and many more frustrating issues. You cant even use the arrow keys to edit your command!
    Up next, a current project I am working on: compiling svr4 for my 3b2. While *technically* the 3B2/300 could not support Release 4, with my upgraded WE32100 I have a good feeling about it. It will most likely strain my 3Mb of RAM as well as run super slow on the 8Mhz clock vs the 10MHz of the 3B2/400. Aside from that, the 400 is architecturally similar to the original 300 (technically it's closer to a 3B2/310, which is basically just a 300 with the WE32100 and 10MHz clock) so I really think this will work. So far I have managed to compile the main tools for building the actual OS. I chose gcc for this task due to the aforementioned AT&T cc having memory issues and not being able to handle compile those tools.
  • Magic Smoke
    Ashton Vallejo • 10/12/2026 at 13:45 • 0 comments
    Now that UNIX was fully backed up and I was free to play around with the machine as I see fit, I decided to play around with the plethora of PORTS and CTC cards that came with the two machines. Some of the cards work as they should, although I had a momentary lapse of reason and decided to plug the cards in without testing them for any shorts or damage. Big mistake. One of the cards apparently had a short across the -12V rail (I am assuming a failed tantulum capacitor) and the line driver chip completely caught fire when I plugged the card in and booted it up. On top of the emotional damage of watching one of the cards self-destruct, the physical damage to the computer was pretty bad. Not only was the card pretty much ruined due to the short, but it also managed to blow another tantulum on the motherboard, shorting the -12V to ground on there too. It also took out the -12V line on the PSU itself. And then to add insult to injury, the thin trace that brought the -12v to the rest of the serial circuitry decided it wanted to be a fuse and burned a hole in the trace, cutting off all -12V to the rest of the motherboard. This was honestly the worst hardware failure I have had yet, as not only did I have to diagnose which capacitor was blown, but I also had to bodge-wire a new trace to the -12V rail. Thankfully I was able to get it up and running again, but the power supply was toast. My knowledge of electronics really ends when I start touching power supplies, and it didnt help that two capacitors exploded while I had the shell off and was testing voltages on the psu. Eventually I gave up trying to fix the old power supply and chose instead to modify an ATX power supply to power the machine. I figured not only would the psu be able to supply way more power than the 3B2 would ever need, but it also has much better protection from overcurrent and short circuits. This honestly wasn't too bad though, and the first version had a physical power and reset button which meant I had to sacrifice the soft power features of the original psu, but at least this time I had a safe power supply to use with it.
  • Backups and Serial Pain
    Ashton Vallejo • 10/12/2026 at 13:28 • 0 comments
    After I was able to get the 3B2 into UNIX, it was time to do some preservation work. I wanted to take a full image of the raw hard drive image, but in the end decided against it due to how time consuming and harsh on the drive it would be. Instead I went with using dd to transfer a cpio archive of the entire filesystem of the 3B2, as all I really cared about was preserving the programs and user files still on the machine. Unfortunately, as I only have PORTS cards with serial ports that are unreliable at speeds higher than 9600 baud, transferring 43 Mb worth of data over a slow serial port was not a pleasant experience. As I remember, the transfer over serial took about 14 hours to complete from start to finish. I ended up having to sleep out in the living room to make sure that the machine would not break or somehow blow up while I slept.
  • Diagnostic Woes
    Ashton Vallejo • 10/12/2026 at 13:19 • 0 comments
    For a while I was convinced that the 3B2 would never boot again. After putting it in it's minimal configuration, the computer refused to run it's self check. I couldn't figure out why the computer would just hang on boot with no console output and indication of an error aside from the diagnostic light staying on no matter how long I left it there. This took me about a month to figure out and it turns out that the whole issue was user error-- The backplane needed to be plugged in all along! It took me forever to realize that there were terminating resistors on the backplane that the computer absolutely requires to boot. Whoops! After I seated the backplane the computer went back to its normal boot procedure and was actually able to fully boot into UNIX this time!!
  • Meet the AT&T 3B2
    Ashton Vallejo • 10/07/2026 at 17:29 • 0 comments
    I had acquired my 3B2 systems at VCF East 2026. When I had found them I knew almost nothing of their existence, and on a whim made the purchase on two 3B2/300s, a tape drive, and an expansion chassis with my only knowledge of them being a quick wikipedia page read while in line to buy them. I've always had an interest in UNIX and in workstations and servers so they caught my attention right away. They were filthy and beat up, but I knew I would get them up and running again.
    Here is our haul back from VCF East, starring the beige beasts.
    After coming home with them the first thing I did was open them up and get a taste for what I was working with. The inside was completely filthy, with 40 years of dust and grime clinging to everything. There was a thick layer of tar on everything, as it was exposed to plenty of smoking during its previous life. One of the hard drives had a bad bearing and was deafening. It was in rough shape.
View all 8 project logs
valkyrie0528 wrote 10/28/2026 at 03:47 • point
This is a really great project and a neat machine, and I appreciate all of the interesting details in your project updates. Particularly the archeological aspects and your attention to preservation are most admirable.
Ken Yap wrote 10/22/2026 at 23:03 • point
All the best in your project. I have vague memories from the mid-80s of helping a colleague who had graduated and was provided with one by her employer. Those were the days when one needed to be aware of BSD/SysV differences. BSD was what the department ran.
WJCarpenter wrote 10/21/2026 at 18:33 • point
Wow. I worked at Bell Labs in the 1980s. I had one of these on my desk as a software development machine. Except for it being really cool in that era to have a real UNIX machine right on my desk, I didn't really understand if there was anything special about them.
I forget how it connected to the rest of the building network, but it might have been Datakit (an AT&T networking scheme). A few years later, I worked on a project that used the big sister 3b2/400 macnines in datacenters. AT&T produced a TCP/IP networking card, but AFAIR, the price was around US$5000 for one card, and it probably only provided 1 Mbps (I could be wrong about that).
Good luck with your restoration.
