I always wanted to build a meshtastic repeater. Some time back I noticed that all the TV antennas on the roof of my home are mounted on this stainless steel pole with some free space at the very top. So I decided on that being the ideal place for a meshtastic repeater.
Rain resistance was insured by 2 o-rings. One on the antenna interface and the other between the top and main body parts. '
Instalation was made fairly simple by the dual dovetail interface with a locking screw securing the mount.
Electronics are fairly simple. It's just a seeed studio ESP32 with a LoRa module. Power comes from 20 meters of USB extention cord running down the roof to my computer.
The USB cable is only used for power since I usually connect via bluetooth instead.
The build is fairly straight forward, with the housing being printed from resin and the red clamps being fmd printed ABS plastic. Everything is held together with screws. Threads in the resin body are just printed with helicoil i
20 m of USB cable has a few ohms of round-trip resistance, so it's worth measuring the 5V at the board while it transmits. If it sags, run 12V down a separate two-core cable and put a small buck converter in the housing. That cable is also a straight path from a metal rooftop pole into your computer's USB port, so make sure the mast is earthed, or power it from a cheap USB charger instead of the PC. And most standard SLA resins go brittle after a summer in the sun, so a coat of outdoor paint will help the housing keep its seal on the o-rings.
Thanks, I'm probably not gonna bother with getting another cable up there but it would be a good idea. Even tho I get only a couple of lightning storms a year, it's a good idea to rewire. My original idea was using the computer as an access point but I found out that the USB-A to USB-C connector I used inside the housing does not transfer data so I cannot use it either way. Found a cheap charger and plugged it into the wall. I'm very aware of the lack of coating, but I thought it would be a good way to actually test how quickly it's gonna fail. So the housing is bad in the name of science :D
