The theory behind a DIY logic probe: 11:1 tip divider, compensation, cable as transmission line, and simple scope-only checks.
This work leans on the people who worked it out in public first. Thomas Scherrer (OZ2CPU) designed and shared the probe most DIY builder’s use. Mike Wyatt (mawyatt) contributed the transmission-line modelling and the flexible base design. tautech, DL2XY and many others in the EEVblog thread measured the original probe and the scope. Any errors here are mine.
The three designs discussed here differ mainly in how they treat the bottom leg of the divider, the part that is already inside the scope.
OZ2CPU (Thomas Scherrer). The design most builders have used: 120Ω and 86.6kΩ ‖ 8.2pF in the pod, 50cm of twisted pair, and only a 120Ω series resistor on a four-layer plug board. At first sight it looks unattenuated, since nothing at the scope end goes to ground. It is not: the scope's own input resistance is the bottom leg. Thomas arrived at 86.6kΩ empirically, trimming a channel from 100kΩ until the switching point matched a known 4.9V signal, which is a measurement of the scope's internal resistor by another route.
mawyatt (Mike Wyatt). A base board with every value left to be chosen, including the two optional capacitors discussed in section 5. It is the most flexible of the three and the most explicit about compensation. Its resistor-to-ground position is the one to be careful with on this scope: it sits in parallel with the internal bottom leg, so it has to stay empty, or be very large, if the ratio is to stay at about 11:1.
The author's design. 90.9kΩ ‖ 5.6pF C0G at the tip, 121Ω at both ends of a 3M 1700/16 cable with every signal twisted with its own ground, and nothing to ground on the plug board. The 90.9kΩ is the E96 value closest to the 91.1kΩ measured in a genuine SPL2016, so the probe presents the same DC load as the original; the 121Ω resistors are matched to the 122Ω balanced impedance of the pairs; and the 5.6pF calls for about 55pF across the bottom leg. Half a metre of this cable supplies roughly half of that; the rest has to come from the plug board, the edge connector and the scope's input, whose capacitance Siglent does not specify, so the duty-cycle test in section 6 is the final judge. The threshold test confirms the ratio (section 6).
The tempting resistor to ground. A textbook divider has two resistors, and it is natural to draw the second one, 9.09kΩ to ground, on the plug board. On an SDS2000X Plus that resistor sits in parallel with the scope's own ~9.1kΩ, the bottom leg falls to about 4.5kΩ and the ratio becomes about 21:1. Every threshold on the screen is then half the real one, the CMOS (2.5V) preset stops working on 3.3V logic, and the compensation needs twice the bottom capacitance. A probe and the input it plugs into are one circuit, and the half inside the instrument is easy to leave out of a schematic or a simulation.
Choosing the tip resistor. The top resistor has to be about ten times the scope's internal resistance. OZ2CPU's 86.6kΩ (about 10.5:1) and the author's 90.9kΩ (about 11:1) both land within the scope's threshold accuracy. Builders using other cables or plug boards can use the same method: run the threshold test, choose the E96 value that makes the window span the full calibrator amplitude, then change the tip capacitor in inverse proportion so that R·C at the tip stays the same.
Two simple tests cover the theory above and need nothing more than the scope itself.
Divider ratio (threshold test). Connect one channel to the scope's 1 kHz calibrator output and step the custom threshold for that group up and down until the channel stops toggling. The channel toggles only while the threshold, as the scope understands it, lies inside the signal's swing. With a correctly matched probe that window spans roughly the calibrator's full amplitude. If it spans about half of it, the probe divides by twenty and every threshold on the screen is half the real one.
The author's probe toggles on the 3V calibrator for any threshold from 0.06V to 3.1V: the full swing, within the scope's specified threshold accuracy of ±(3 % + 200mV). It also triggers correctly with every preset: TTL, CMOS, LVCMOS 3.3V and LVCMOS 2.5V. A probe that divides by twenty would lose the signal already at about 1.5V, and the 2.5V CMOS preset would fail on a 3V signal.
Threshold accuracy (DC test). For a closer look, set a threshold, feed the channel a slowly adjustable DC level from the scope's AWG, and note where the channel switches going up and going down. On the author's probe, a 1.00V setting switches at 0.93V rising and 0.91V falling, and a 2.00V setting at 1.9V and 1.8V. Both switch at about 0.92 of the set value, so it is a scale (gain) error of about 8 %, not an offset. Switching below the setting means the probe divides slightly less than the scope assumes: the scope behaves as if the probe were about 12:1. A tip resistor about 8 % higher (for example 100kΩ instead of 90.9kΩ) would centre it. There is little reason to: the error is about 80mV at a 1V setting, well inside the threshold accuracy of ±(3 % + 200mV) listed in the SPL2016 datasheet, which is ±230mV at 1V.
Compensation (duty-cycle test). Feed a square wave with fast edges, for example a 74HC-family gate clocked at a few MHz, and read the duty cycle while stepping the threshold across the signal. Constant duty cycle means a flat divider. Duty cycle that grows or shrinks with threshold means the tip capacitor is too small or too large for the cable and scope behind it.
The ohmmeter also helps, with one caution. With the probe unplugged, each channel should read the tip resistor plus the two series resistors from tip to plug pin, and open circuit between neighbouring conductors. Plugged in, a reading from tip to ground includes the scope's internal bottom leg, but it is measured through the scope's ESD diodes and bias network, so it changes with test-lead polarity and with whether the scope is powered. It is useful for spotting a broken channel, not for measuring the divider ratio; the threshold test does that better.
Mike Wyatt (mawyatt on EEVblog) drew up a "logic analyzer base" for the scope end in March 2021 with every value marked TBD: a series resistor, a resistor to ground, a capacitor to ground on the scope side of the resistor, and a second capacitor to ground on the cable side. His pencil sketch of the full chain gives starting values: 250Ω and 90.9kΩ ‖ 8.2pF in the pod; 370Ω series, 7.4pF "including DSO capacitance and connector" and 1.5pF "including pad capacitance" in the base.
The two capacitors are there for different reasons:
"Optional" is the key word. The base is best read as a flexible platform: populate nothing and it behaves like the simpler designs; populate the capacitors and it can be tuned to a particular cable and scope. The cost is that the builder has to measure and choose, which the fixed-value designs avoid by picking values that work for a known cable length.
Half a metre of cable is about 2.7 ns of delay (3M 1700 series: 5.35 ns/m, velocity factor 0.62). A logic edge from a modern CMOS part rises in 1 to 2ns, shorter than the round trip down the cable and back. For those edges the cable is not a capacitor but a transmission line, and the design has to decide what happens to the reflections.
Pairing. In the author's probe every signal conductor in the 16-way 3M 1700/16 cable is twisted with its own ground conductor, eight pairs per pod. Each channel is then a balanced pair with a characteristic impedance of about 122Ω, its own return path, and a small loop area. Crosstalk between channels drops sharply compared with a plain ribbon where eight signals share one or two grounds, and the return current of each edge flows right next to its signal.
The receiving end is effectively open. The scope end presents about 9kΩ, a hundred times the cable impedance. An edge arriving there reflects with almost the full amplitude and travels back towards the tip.
The series resistors. Both the pod and the plug carry a 121Ω resistor in series with each signal (120Ω in OZ2CPU's design, 250Ω and 370Ω in mawyatt's sketch). They are not terminators in the usual sense, because neither end is a matched load, but they do two jobs:
The value is chosen to match the cable, which is why the author picked 121Ω (E96) for a 122Ω balanced pair, and why OZ2CPU notes that coax builds need around 75Ω. The combined effect is a step at the comparator that settles within one round trip and crosses the threshold once.
Why not coax. The SPL2016 itself uses a multi-coax cable (about 45Ω, 6.1 ns for 1.1 m). Coax gives the best isolation between channels but is expensive in 16-way form and stiff; twisted-pair flat cable is a very good compromise for the half-metre lengths a bench probe needs, and it is available off the reel.
A resistive divider with stray capacitance on its bottom leg is a low-pass filter with a time constant in the hundreds of nanoseconds, which is useless for logic signals. The cure is the one every ×10 passive probe uses: bridge the top resistor with a capacitor so that the divider is capacitive at high frequency and resistive at low frequency, and choose the capacitor so that both ratios are the same.
The divider is flat (frequency independent) when
ut numbers on it. With 90.9kΩ and 5.6pF at the tip,
If the bottom leg is the scope's ~9.1kΩ, the bottom capacitance must be about 55pF. That capacitance is not a component; it is the sum of
For OZ2CPU's values, 86.6kΩ × 8.2pF = 710 ns, asking for about 74pF across the bottom leg. The differences between 5.6pF and 8.2pF designs are mostly differences in cable length and cable type.
What goes wrong when the rule is not met is subtle on a logic channel, because there is no trace on the screen to show overshoot or droop. Instead, the error appears as timing:
Both show up as a duty cycle that changes when you move the threshold. That gives a practical test: feed a clean square wave, measure its duty cycle with the scope's digital measurements, and sweep the threshold from 20 % to 80 % of the signal amplitude. A compensated probe gives the same duty cycle across the sweep.
Use C0G/NP0 capacitors. At 5.6pF, the voltage and temperature coefficients of X7R would move the compensation around by tens of percent.
A logic probe could in principle be a bundle of wires straight to the comparators. Every serious logic-analyser probe since the 1980s has instead put a large resistor right at the tip, and the reasons still apply:
The models in the SDS2000X Plus series, from 100MHz to 500MHz, share the same logic-analyser input and the same SPL2016 probe. The author's measurements were made on an SDS2104X Plus. Any of them turns into a 16-channel mixed-signal oscilloscope when a logic probe is plugged into the slot marked D0–D15 on the front panel. The slot is mechanically a PCIe x1 edge connector, but electrically it has nothing to do with PCI Express: 16 signal pins, each flanked by ground pins, feed 16 comparators inside the scope.
Siglent's own probe, the SPL2016, is specified as:
| Parameter | SPL2016 |
| Input impedance at the tip | 100kΩ ‖ ~18pF |
| Input dynamic range | ±20V |
| Threshold range | ±10V, 10mV steps |
| Threshold presets | TTL 1.5V, CMOS 2.5V, LVCMOS 3.3V (1.65V), LVCMOS 2.5V (1.25V) |
| Minimum input swing | 800mVpp |
| Maximum data rate | 300Mbit/s |
| Threshold groups | D0–D7 and D8–D15 |
The numbers that matter for a DIY design are not printed there, because they are properties of the scope, not of the probe:
The rest of the design follows from these three facts.
The author's probe on an SDS2104X Plus: 3M twisted-pair flat cable, 3D-printed plug shell and two eight-channel pods, with D0 on the 1kHz calibrator.
macafeeje
Christoph
Bud Bennett
ISAI B
