Intel 8085 – KE6JMG ASCII Banner Display
An Intel 8085 assembly program displaying KE6JMG in large ASCII characters using a font table and SDK-85 emulator.
0 followers
Intel 8085 – KE6JMG ASCII Banner Display This project demonstrates how the vintage Intel 8085 microprocessor can generate large ASCII character banners using assembly language, character font tables, and serial terminal output. The initial demonstration displays my amateur radio callsign, KE6JMG, using a custom machine-language program running on an emulated Intel SDK-85 development system. The SDK-85 emulator was compiled under Ubuntu Linux using Windows Subsystem for Linux (WSL) on Windows 11. The program reads character patterns from memory and converts them into large, multi-line ASCII characters for display on a serial terminal. Project logs will document the Linux installation commands, emulator compilation, Intel 8085 machine-code listings, font tables, and modifications to the emulator. A future goal is to connect the emulator to a real ASR-33 Teletype through a Teensy 4.1 serial interface operating at 110 baud.
Introduction
This project brings together vintage Intel 8085 microprocessor programming, an emulated Intel SDK-85 development system, and large-character ASCII banner generation.
The objective is to display my amateur radio callsign, KE6JMG, using an Intel 8085 machine-language program and a character font table.
The project also explores how a modern computer can communicate with vintage electromechanical equipment, particularly the ASR-33 Teletype.
The SDK-85 Emulator
The development environment uses an open-source Intel SDK-85 emulator compiled under Ubuntu Linux through Windows Subsystem for Linux (WSL) on Windows 11.
The emulator provides an environment for entering, examining, and executing Intel 8085 machine-code programs.
When started in serial terminal mode, the emulator displays:
SDK-85   VER 2.1
The SDK-85 monitor supports commands for examining memory, entering machine code, and executing programs.
For example:
.D2000
.I2000
.G2000
These commands allow the banner program to be developed and tested without requiring a physical SDK-85 board.
Character Generation
The banner generator uses a font table stored in the emulated 8085 memory.
Each character is represented by a series of patterns describing its shape. The 8085 program reads these patterns and produces multiple rows of printable ASCII characters.
The initial demonstration generates the callsign:
KE6JMG
The design is intended to be expanded to support a complete character set, including uppercase letters, numbers, punctuation, and spaces.
A table-driven approach allows new messages to be displayed without rewriting the entire character-generation routine.
Emulator Development
The SDK-85 emulator was compiled using standard Linux development tools.
Additional work has included developing a startup menu with options for:
  1. Serial / TTY mode
  2. SDK-85 keypad and display mode
  3. Rebuilding the emulator
  4. Exiting the program
A planned enhancement is to load the banner program and font table automatically when the emulator starts.
This will eliminate the need to manually enter machine-code bytes each time the program is demonstrated.
ASR-33 Teletype Interface
A future demonstration will connect the emulator to a real ASR-33 Teletype.
The ASR-33 uses 110-baud serial communication and a 20 mA current-loop interface.
A Teensy 4.1 microcontroller provides serial conversion between the computer and the Teletype, including character translation and timing adjustments.
The goal is to have the Intel 8085 program generate the KE6JMG banner while the ASR-33 prints the characters mechanically.
Documentation
The project logs and build instructions will include:
  • Ubuntu and WSL installation instructions
  • Linux compilation commands
  • SDK-85 emulator configuration
  • Intel 8085 machine-code listings
  • Character font tables and memory maps
  • Emulator menu modifications
  • Serial communication experiments
  • ASR-33 Teletype integration
Computer-specific usernames, hostnames, and private directory paths will be replaced with generic examples in the published documentation.
Conclusion
This project demonstrates that classic 8-bit microprocessor programming remains useful for learning about memory organization, character generation, serial communication, and embedded software design.
The ultimate goal is to combine a working Intel 8085 software environment with authentic vintage Teletype hardware, bringing early microprocessor technology back to life.
Here below is a video of operating the emulator:
  • Connecting the SDK-85 Emulator to a Real ASR-33 Teletype
    Harold Moore • 10/15/2026 at 15:57 • 0 comments
    This project has now reached one of its main goals: connecting the Intel SDK-85 emulator running on a modern Windows computer to a real ASR-33 Teletype.
    The complete communication path is:
    SDK-85 Emulator → Windows/WSL → USB → Teensy 4.1 → RS-232 → 20 mA Current Loop Interface → ASR-33 Teletype
    Communication is bidirectional. Commands typed on the ASR-33 keyboard are sent back to the SDK-85 emulator, and output from the emulated SDK-85 is printed by the ASR-33.
    For the final demonstration, an original 8085 machine-language banner program is preloaded into emulator RAM. From the ASR-33 keyboard I enter G2010, which starts the program and prints my amateur radio callsign KE6JMG as a large ASCII banner. When the program finishes, control returns to the SDK-85 monitor.
    ASR-33 Interface Hardware
    The ASR-33 does not use a modern USB or conventional TTL serial interface. Its communications interface uses a 20 mA current loop, so an interface is required between the Teletype and the modern computer.
    I used a 20 mA current-loop to RS-232 converter, followed by an RS-232 interface connected to a Teensy 4.1. The Teensy provides the USB connection to the Windows computer and also handles the 110-baud serial communications required by the ASR-33.
    The Teensy operates as a bidirectional bridge. Data received from the ASR-33 is converted to clean 7-bit ASCII and sent to the computer. Data coming from the SDK-85 emulator is sent to the ASR-33 at 110 baud. A short delay following carriage return allows the mechanical carriage enough time to return before additional characters are transmitted.
    Because ASR-33 terminal-strip connections can vary between machines, the current-loop connections should be identified as TX+, TX−, RX+ and RX− rather than assuming particular terminal numbers.
    20 mA Current-Loop to RS-232 Interface
    This is the interface used between my ASR-33 Teletype and the RS-232 side of the Teensy interface. I redrew the schematic for this project and adapted the RS-232 connections for my particular setup.
    The current-loop converter is based on Schematic 1.1 from The Retro Wagon's “20mA Current Loop to RS-232 Conversion” project, which in turn documents an interface derived from the AltairClone design. My ASR-33 terminal-strip connections are shown for reference; terminal numbering may differ on other ASR-33 machines.
    Reference:
    The Retro Wagon — 20mA Current Loop to RS-232 Conversion
    RS-232 to Teensy 4.1 USB Interface
    This schematic shows the second half of the interface. The RS-232 signal from the current-loop converter is translated to logic levels for the Teensy 4.1. The Teensy then provides the USB serial connection to the Windows computer.
    The Teensy firmware performs the serial bridging in both directions. The ASR-33 side operates at 110 baud using 7-bit ASCII, while the USB connection appears to Windows as a COM port.
    Together, these two interface circuits allow a real electromechanical ASR-33 to operate as the terminal for the emulated Intel SDK-85.
    The Completed Teensy 4.1 / ASR-33 Interface
    This is the completed interface operating on the bench. The Teensy 4.1 provides the bridge between the modern computer and the RS-232/current-loop hardware connected to the ASR-33.
    The Teletype printout below the interface shows the actual result of the demonstration. The ASR-33 receives the SDK-85 monitor sign-on, I enter G2010 from the Teletype keyboard, and the 8085 program prints the large KE6JMG banner.
    This confirms operation in both directions—the ASR-33 is not simply being used as a printer; it is functioning as the interactive terminal for the SDK-85 emulator.
    ASR-33 Running the SDK-85 Banner Program
    The following video shows the complete system operating with the real ASR-33 Teletype.
    The SDK-85 emulator is running on the computer and communicating through the Teensy 4.1 and the RS-232/20 mA current-loop interfaces. The ASR-33 receives the familiar SDK-85 VER 2.1 monitor prompt.
    From the ASR-33 keyboard, I enter...
  • Project Log #2
    Harold Moore • 10/12/2026 at 20:47 • 0 comments
    Project Log #2 — Programming the Intel 8085 to Display KE6JMG
    Introduction
    With the Intel SDK-85 emulator successfully compiled and running under Ubuntu Linux, the next step was to develop an Intel 8085 machine-language program capable of producing a large ASCII-character banner.
    The objective was to display my amateur radio callsign:
    KE6JMG
    The program was developed using the SDK-85 monitor, with machine-code instructions entered directly into the emulator's memory.
    The finished demonstration produces an eight-line banner using printable ASCII characters and a compact method of encoding repeated spaces.
    This project log contains the recorded machine-code program, complete banner data, monitor commands, and terminal output.
    1. The Intel SDK-85 Emulator
    The emulator used for this project was originally developed by Kjetil, known as kobolt on GitHub.
    Original source repository:
    https://github.com/kobolt/sdk85emu
    The emulator is distributed under the MIT License.
    The software emulates the Intel 8085 processor and SDK-85 development environment, including the monitor and serial terminal facilities.
    My project uses this emulator to develop and execute an original ASCII banner demonstration.
    2. Program Design
    The banner generator separates the executable machine-code routine from the ASCII banner data.
    The executable program reads bytes sequentially from memory, interprets their values, and sends the resulting characters to the SDK-85 terminal.
    The program supports three important operations:
    1. Printing ordinary ASCII characters.
    2. Expanding encoded space characters into multiple spaces.
    3. Processing carriage returns to create multiple lines of output.
    A zero byte marks the end of the banner data.
    This approach reduces the amount of memory required to store large banners containing substantial blank space.
    3. Memory Organization
    The program uses the following memory locations:
    Purpose
    Executable Intel 8085 program
    Encoded KE6JMG banner data
    End-of-data terminator
    SDK-85 monitor output subroutine
    The machine-code routine begins at address 2010H.
    The banner data begins at 2800H and is processed sequentially.
    The program calls the SDK-85 monitor's output routines to generate the display.
    The byte at 2900H is set to zero, providing an end-of-data marker.
    4. Starting the Emulator
    Open the Ubuntu Linux terminal.
    Change to the SDK-85 emulator directory:
    cd ~/sdk85emu
    Start the emulator in serial terminal mode:
    ./sdk85emu -s
    The emulator displays:
    SDK-85   VER 2.1
    The period is the SDK-85 monitor prompt.
    The following commands are entered into the SDK-85 monitor, not the Linux shell.
    5. Entering the Intel 8085 Machine-Code Program
    At the monitor prompt, enter:
    .I2010
    Then enter the following hexadecimal bytes:
    31 C2 20 21 00 28 7E 4F 23 FE 00 CA 90 05 07 DA
    34 20 0F FE 0D CA 2E 20 CD FA 07 C3 16 20 CD EB
    05 C3 16 20 0F E6 7F 57 0E 20 CD FA 07 15 C2 38
    20 C3 16 20 00
    Finish the memory-entry operation using:
    This is the machine-code sequence recorded during the successful development session.
    The program initializes its working registers, reads encoded banner data, and uses the SDK-85 monitor routines for terminal output.
    6. Entering the Complete KE6JMG Banner Data
    The banner data is stored separately from the executable instructions.
    .I2800
    Enter the following hexadecimal bytes exactly as shown:
    85 4B 20 20 4B 20 45 45 45 45 20 20 36 36 20 20
    20 4A 4A 4A 20 4D 20 20 20 4D 20 20 47 47 47 0D
    85 4B 20 4B 20 20 45 20 20 20 20 36 20 20 20 20
    20 20 20 4A 20 4D 4D 20 4D 4D 20 47 20 20 20 0D
    85 4B 4B 20 20 20 45 20 20 20 20 36 20 20 20 20
    20 20 20 4A 20 4D 20 4D 20 4D 20 47 20 20 20 0D
    85 4B 20 4B 20 20 45 45 45 20 20 36 36 36 20 20
    20 20 20 4A 20 4D 20 20 20 4D 20 47 20 47 47 0D
    85 4B 20 20 4B 20 45 20 20 20 20 36 20 20 36 20
    20 20 20 4A 20 4D 20 20 20 4D 20 47 20 20 47 0D
    4A 20 20 4A 20 4D 20 20 20 4D 20 47 20 20...
  • Project Log #1
    Harold Moore • 10/12/2026 at 20:23 • 0 comments
    Project Log #1 — Installing and Compiling the Intel SDK-85 Emulator Under WSL
    Introduction
    The first step in developing the KE6JMG ASCII Banner Display was establishing a working Intel SDK-85 emulator.
    The Intel SDK-85 was a development system designed around the Intel 8085 8-bit microprocessor. It provided a platform for experimenting with machine-language programming, memory operations, peripheral interfaces, and serial communications.
    For this project, I am using an open-source SDK-85 emulator running under Ubuntu Linux through Windows Subsystem for Linux (WSL) on a Windows 11 computer.
    This log explains how to obtain the original emulator, install the necessary development tools, compile the software, and run the SDK-85 monitor.
    1. Original Emulator and Author Credit
    The Intel SDK-85 emulator used in this project was originally developed by Kjetil, known as kobolt on GitHub.
    Original GitHub repository:
    Original project documentation:
    https://kobolt.github.io/article-250.html
    The original emulator is distributed under the MIT License.
    Kjetil's software provides an emulated Intel 8085 processor, SDK-85 keyboard and display interface, serial terminal operation, memory support, and debugging facilities.
    The original emulator includes:
    • Intel 8085 CPU emulation
    • Intel 8279 keyboard/display interface
    • SDK-85 monitor ROM
    • Serial terminal operation
    • Debugging and breakpoint capabilities
    • Intel HEX ROM loading
    • Additional memory support
    Full credit for the original emulator belongs to Kjetil.
    My KE6JMG project builds upon this work by developing a custom Intel 8085 ASCII banner program, experimenting with character font tables, modifying the emulator startup environment, and investigating communication with an actual ASR-33 Teletype.
    The original copyright and license notices will be preserved in any redistributed modified emulator source code.
    2. Installing Windows Subsystem for Linux
    The development computer uses Windows 11.
    WSL allows Ubuntu Linux and its development tools to operate within Windows without requiring a separate Linux computer.
    Open Windows PowerShell as Administrator and enter:
    wsl --install -d Ubuntu
    Windows may request a restart.
    After restarting, open Ubuntu from the Windows Start menu.
    During the initial setup, Ubuntu will request a Linux username and password.
    To verify the installation, open PowerShell and enter:
    wsl --list --verbose
    The installed Ubuntu distribution should appear.
    3. Updating Ubuntu Linux
    Open the Ubuntu terminal.
    Update the package information:
    sudo apt update
    Upgrade installed packages:
    sudo apt upgrade -y
    These commands prepare the Linux environment for software development.
    4. Installing the Development Tools
    The SDK-85 emulator is written in C and uses terminal display libraries.
    Install the required development tools:
    sudo apt install -y build-essential make libncurses-dev git
    These packages provide:
    • GCC — GNU C compiler
    • Make — software build utility
    • ncurses — terminal display library
    • Git — source-code retrieval utility
    Verify that the compiler is available:
    gcc --version
    Verify Make:
    make --version
    Verify Git:
    git --version
    5. Downloading the Original SDK-85 Emulator
    The original source code is publicly available from Kjetil's GitHub repository.
    For a straightforward Linux installation, open the Ubuntu terminal and enter:
    cd ~
    Download the source:
    git clone https://github.com/kobolt/sdk85emu.git
    Enter the project directory:
    cd ~/sdk85emu
    Examine the downloaded files:
    ls -la
    The source directory contains several important files, including:
    Makefile
    main.c
    i8085.c
    i8085.h
    serial.c
    serial.h
    mem.c
    mem.h
    monitor.hex
    mcs85util.hex
    The monitor.hex file contains the SDK-85 monitor ROM image.
    The i8085.c source provides the Intel 8085 CPU emulation.
    The serial.c source handles serial communications.
    The Makefile contains the instructions required to compile the emulator.
    Note: During...
View all 3 project logs
