I made RetroPrompt to recreate a familiar retro-computing scene at miniature scale: a CRT-style monitor displaying a blinking DOS prompt.
I combined a 0.42-inch OLED with a 3D-printed, spray-painted enclosure and a resin-cast lens. The casing has a deliberately worn, discolored finish to resemble vintage computer hardware. A micro-USB connection supplies power.
The screen shows a C:\> prompt with a flashing cursor. RetroPrompt is a decorative electronic miniature; it does not accept commands or run MS-DOS.
I’m documenting this project after completing it. The photographs show the illuminated screen, enclosure, rear connector, and miniature scale.
I made RetroPrompt out of nostalgia for early computers, especially the first computer I used as a child. I wanted to bring a little of that feeling back in a miniature monitor, with a DOS prompt and a blinking cursor.
Existing demonstration of the completed RetroPrompt.
Inside is a 0.42-inch OLED. I made a custom mold for the epoxy-resin lens, which gives the screen the curved face of an old CRT. I chose a Padauk 150C microcontroller because it was cheap and small.
RetroPrompt miniature CRT-style monitor held between fingertips, displaying an MS-DOS command prompt.
At first, I made the C:\> prompt proportional to the miniature monitor. But scaled down that way, it was too tiny. I deliberately enlarged it, exaggerating the prompt so it would stand out on the little screen.
That change also made the whole thing look cuter, almost like a caricature of an old monitor. The oversized prompt gives it a playful, Q-version feel. That was a side effect of making the text bigger, rather than the starting point for the design.
RetroPrompt miniature CRT-style monitor beside a coin for size comparison.
RetroPrompt is a desk decoration powered through micro USB. The prompt doesn't accept commands, but its blinking cursor brings that familiar early-computer scene into miniature.
