I made this miniature oscilloscope to recreate the appearance of vintage test equipment as a small animated desk decoration. A 0.32-inch OLED displays a noisy, moving waveform intended to evoke the jitter and glow of a classic CRT oscilloscope. The waveform is simulated; the miniature does not measure external signals.
The enclosure is 3D-printed and spray-painted with an aged finish. Mock control dials and a textured exterior carry the instrument theme beyond the screen, giving the tiny object the appearance of well-used bench equipment. The photographs show the enclosure on its stand, alongside a coin, and resting in a hand to demonstrate its scale.
Power comes through a micro-USB connection. Plugging it in illuminates the display and brings the waveform animation to life. I combined a very small modern display with the visual language of older laboratory instruments.
The main challenge with my miniature oscilloscope was getting the waveform animation to look convincing. It needed to loop continuously while keeping the appearance of a signal moving across the screen. That animation took more work than the tiny display might suggest.
Existing demonstration of the completed Miniature Oscilloscope.
I used a 0.32-inch OLED for the screen. The animation data is stored bit by bit in EEPROM, and the microcontroller reads that data and displays the animation on the OLED.
The finished miniature has a moving, noisy waveform, with a grid and small mock controls giving it the appearance of an older bench instrument. The waveform is simulated, so this is a decoration rather than a tool for measuring signals. Power comes through micro USB, and the animation keeps looping on the little screen.
Miniature vintage oscilloscope decoration displaying a cyan waveform grid with a white cable connected.Front view of the miniature oscilloscope decoration with small controls and a dark screen.
