WHY 96 kHz / 24-bit
Most TOSLINK to USB capture devices available at a reasonable price stop at 48 kHz / 16-bit. This unit captures Hi-Res 96 kHz / 24-bit sources without any conversion, as well as 88.2 / 48 / 44.1 kHz.
STANDALONE RECORDER VS PC CAPTURE
The S/PDIF TOSLINK WAV Recorder is built for standalone archiving: insert a microSD card and it writes WAV files on its own, with no PC involved. S/PDIF USB Capture takes the other route. The audio arrives in the PC as a live input stream, and the processing after that is open to whatever the PC can run:
- Capture to WAV or FLAC with Audacity or any recording application
- Encode to MP3 or other formats on the fly while capturing
- Monitor and edit the stream in a DAW
- Feed the stream into your own software for analysis or custom processing
No dedicated software is provided. The unit is recognized as a standard audio input device, and any software that can capture from an audio input should be able to use it.
BIT-PERFECT PATH
The PCM data from the S/PDIF input is passed to USB without any change. There is no volume control, no resampling and no mixing in the unit. Set the PC input format to the source rate to capture the stream without resampling on the PC.
The unit has no level control of its own. If the level needs adjusting, adjust it outside the unit: on the source side, or in the application after capture. If the captured level looks lower than expected, check the volume normalization of the source player.
SAMPLE RATE HANDLING
The unit detects the sample rate of the S/PDIF source and shows it on the FREQ LEDs. The input format of the PC decides the rate of the USB stream:
- Windows: Settings > System > Sound > Input > SPDIF Interface > Format
- Linux (PipeWire): pw-metadata -n settings 0 clock.force-rate 96000
When the two rates match, the audio is captured. When they do not match, the unit captures silence and the STATUS LED turns red, which makes a wrong setting easy to spot.
LED INDICATORS
STATUS (green / red) shows the USB and S/PDIF state, and FREQ shows the detected source rate.
- Red, short blink: power only, the PC does not recognize the unit
- Red, slow blink: USB recognized, the audio driver of the PC has not started
- Green: ready (FREQ off: no S/PDIF signal, FREQ on: rate matched)
- Red: rate mismatch, silence is captured
- Green, slow blink: streaming, an application has opened the unit
- All off: no USB power, or PC sleep
SPECIFICATIONS
Sample rates: 96 / 88.2 / 48 / 44.1 kHz
Resolution: 24-bit stereo
Input: TOSLINK optical (S/PDIF), linear PCM
Output: USB Type-C, USB 2.0 Full Speed, USB Audio Class 2.0
Indicators: STATUS LED (green / red), 4 FREQ LEDs
Power: USB bus powered
Supported OS: Windows 11, Linux
Enclosure: aluminum case, PCB front and rear panels with corner screws
Dimensions: 31.0 mm (W) x 25.2 mm (H) x 72.2 mm (D), including protruding parts
Weight: 48 g
NOTES
The source must output linear PCM. Compressed formats such as Dolby Digital and DTS are not supported.
ADAT (multichannel optical) is not supported. Set the optical output of the source to S/PDIF.
Sample rates above 96 kHz are not supported.
For a coaxial S/PDIF source, use a coaxial to optical converter.
USB and TOSLINK cables are not included.
macOS has not been tested yet and is not officially supported.
Elehobica
jeff
Sylwester
ICantMakeThings
