Water Condensation Sensor with Fine PCB Traces
A two-terminal condensation sensor with 0.2 mm traces for detecting small water droplets on its surface.
I wanted to detect small water droplets that form through condensation. This board uses fine 0.2 mm traces for that purpose. Connect one pin to ground and the other to an analog or digital input with a pull-up. Condensation on the sensor surface creates a conductive path that pulls the input toward ground. Here I’m documenting the completed sensor board and its connection method.
I wanted to detect the fine droplets that form through condensation, rather than waiting for rain-sized drops. When I couldn't find a suitable sensor, I made this board with 0.2mm-thin traces to bring the sensing pattern down to that scale.
Water on the surface creates a conductive path between the traces. Connect one terminal to ground and the other to an input with a pull-up; condensation pulls that input toward ground. That keeps the interface simple enough to try with a microcontroller before designing a larger control system.
A fogging bathroom mirror is an everyday example of the event this board targets. It detects moisture that has actually condensed on its surface, rather than providing a calibrated air-humidity reading.
More product information: https://www.questwiseventures.com/products/water-condensation-sensor-board
Other possible applications include experimenting with condensation inside an enclosure or logging when a monitored surface becomes wet and dries again. These would need testing in the actual installation. Placement matters because the board senses water on its own surface, rather than measuring the surrounding air’s humidity.
  • Fine traces and drying droplets
    Michael Yim • 10/17/2026 at 15:58 • 0 comments
    I placed the sensing traces close together so that even small droplets could bridge them. That spacing was how I aimed to detect condensation early, while the droplets were still small.
    As the water dries, the reading returns to normal by itself. I tried the board in a real lunchbox and found the detection stable.
  • Looking for droplets inside a lunchbox
    Michael Yim • 10/17/2026 at 15:57 • 0 comments
    My first use for this board was inside a lunchbox, on the inner surface of the lid. I wanted to know when water droplets had actually formed on that surface.
    An ambient humidity reading would tell me something different. For this project, the thing I wanted to detect was the condensed water itself. Detecting condensation in a bathroom during a shower was a later use case.
View all 2 project logs
